Ridgid Wet Saw - Tools - DIY Chatroom Home Improvement Forum
Old 02-24-2009, 09:15 PM   #1
LVH
Ridgid Wet Saw
I just bought the Ridgid WTS2000L Wet Tile saw. I'm having problems cutting 20" X 20" porcelain tile. I'm not getting a straight edge cut. The saw is chipping the tile. The size of the chip is about 1/16 to 1/8 of an inch along the cut. Is it possible to get a straight edge cut with a wet saw? Could it be that my wet saw is defective. I change two blades made by different manufacture and exchange the Ridgid for another one but still have the same problem? is anyone else having this problem? If so, any recommendation on a better wet saw?
LVH is offline   Reply With Quote
Old 02-24-2009, 10:16 PM   #2
Remodeling Contractor
Diamond blades are not all created equal. For porcelain and especially glass tiles use a better grade blade. I use a blade made for glass tile cutting. It will contain finer diamonds packed more densely on the blade.
Old 02-24-2009, 11:12 PM   #3
Registered User
Termite's Avatar
Also make sure you're not feeding the tile too fast.
Old 03-14-2009, 01:03 AM   #4
Brand
What brand of blade would you recommend for cutting ceramic/porcelin tile?
Thank you.
fyreme is offline   Reply With Quote
Old 03-14-2009, 07:59 AM   #5
I use a MK-215GL for glass and a TX-30 pro blade for porcelain. I do not use ceramic much other than porcelain ceramics.
Old 02-05-2017, 09:21 AM   #6
Rewards Points: 2
Re: Ridgid Wet Saw
The first thing you need to do is align the saw. The blade may not be 90 degrees to the table and the 90 degree to the guide. Look back at the instruction for the saw to see how to adjust it. I just bought a Rigid R4040 and I have to realign both to get it set correctly. I also increase the water flow on the pump. I did buy a new blade because of the number of cuts I had to make with my saw. I am beveling some of my tile to reduce the edge surface that is visible. Good luck with adjusting you saw.
aspen2001 is offline   Reply With Quote
Ridgid 18v vs Dewalt 14.4v xrp vs el cheapo? scottrob Tools 28 05-08-2009 09:45 AM
Best Table Saw?? abefroman Tools 15 03-01-2009 05:15 PM
Best Budget Table saw bc0604@yahoo.com Tools 19 02-06-2009 02:33 PM
Ridgid or troy bilt Pipeline Tools 1 11-23-2008 12:41 PM
Ridgid Miter Saw Utility Vehicle - $99 MoJoe Tools 2 03-05-2006 11:41 AM
