Ridgid Air Compressor Low Pressure Output - Tools - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 05:58 PM   #1
ridgid air compressor low pressure output
my OL50135 ridgid air compressor is not producing enough pressure to even inflate car tires, not sure when this happened. i haven't changed the air filter in the 5 or 6 years i've had it (although i don't use it that much) and was planning on changing that, anything else i should check?
the manual says the following:
1. Broken reeds
2. Connections leaking
3. Dirty filter
PapaKlix is offline   Reply With Quote
Old 01-02-2012, 06:02 PM   #2
Rewards Points: 13,458
Ok, and did you cheak any of these?
Old 01-02-2012, 09:05 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
is the bleeder valve closed, do you have the regulator dialed up?
woodworkbykirk is offline   Reply With Quote
Well Water, Fluctuating Water Pressure, and the Roller Coaster Pressure Gauge huuuss Plumbing 24 12-11-2011 09:03 PM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 01:28 PM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 01:37 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
pressure tank problem? steel Plumbing 14 07-03-2008 02:06 PM
