Reviving Dead 18 Lithum Ion Batteries - Tools - DIY Chatroom Home Improvement Forum
Old 11-21-2013, 08:52 PM   #1
Rewards Points: 512
reviving dead 18 lithum ion batteries
i have 3 18v ridgid batteries that no longer hold a charge and they do the death flash on the charger. i wasnt to bright and didnt fill out the lifetime warranty 4-5years ago. where can i order new cells for these batteries?
princelake is offline   Reply With Quote
Old 11-22-2013, 03:48 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
just buy new batteries.. ive heard horror stories of guys trying to rebuild their batteries themself only to have the tool catch on fire because they dont know what their doing.. if its an older drill chances are you wont even be able to get those batteries anymore
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
PaliBob (11-24-2013)
Old 11-22-2013, 05:27 PM   #3
PoleCat's Avatar
Rewards Points: 1,646
I looked into rebuilding my Ryobi batteries. Cost twice as much as buying a new battery.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 11-22-2013, 08:26 PM   #4
Rewards Points: 512
the 3 batteries are the ridgid X3 batteries. i went and just bought a impact/drill kit with a radio and 2 batteries and i bought a 3rd 2.0ah battery so im back up to 3 batteries. i was hoping to rebuild the old batteries so i have 6 but mehhh maybe i'll just by a few more
Old 11-22-2013, 11:29 PM   #5
Registered User
Rewards Points: 5,236
Re-new a Nicad battery.
Gary
Old 11-23-2013, 08:05 AM   #6
Rewards Points: 194
Originally Posted by gtortuga View Post
I have done this many times (5) or more and it has worked every time.
Take your ni-cad (only) battery pack and determine polarity of each contact surface.
Then, (I use a 12v car battery charger as a hi voltage DC device) using the same polarity + to + and - to -, briefly touch (1 second at a time) both contact surfaces of your battery pack. It will spark a little.
That's it! Simple and effective. Your battery pack should show good voltage and hold a charge now.
Note; some battery packs are too far gone to be revived by this method but it works most of the time. Cheap too! You have just burned off the small crystalline connections that have formed inside your ni-cad battery that had effectively shorted it out. Burning off these "dendrites" revives your battery.
GTORTUGA
This sounds like a good way to cook your battery.
Larryh86GT is offline   Reply With Quote
Old 11-24-2013, 12:47 AM   #7
. It works. I have done it.
toolaholic is offline   Reply With Quote
Old 11-24-2013, 08:18 AM   #8
Rewards Points: 194
Interesting. It might be worth a try.
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 10:38 PM
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 09:55 AM
Eliminate Dead Batteries in Thermostat Codywookman Electrical 24 12-13-2009 02:15 PM
Dead Batteries on power tools pawned Tools 25 11-07-2007 12:11 AM
