Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-23-2010, 02:32 AM   #1
Restoring an old Bandsaw
I've got a 1951 Craftsman 3-wheel bandsaw that I'd like to get up and running again. Job one is finding a motor for it. I need a 1725 rpm enclosed 110v motor anywhere from 1/4 to 1/2 hp -- with a 3-inch pulley on it, if possible.
I don't care about authenticity nearly much as I do about saving money. I've been wondering if there's a motor commonly used in a dishwasher or furnace that might work for this application.
Anyone got any ideas?
Jack Olsen is offline   Reply With Quote
Old 02-23-2010, 08:53 AM   #2
Hi Jack.
Try browsing through the Old Wood Working Machines forums. Lots of great info there on old tools.
Good luck with the quest.
itin1200 is offline   Reply With Quote
Old 02-26-2010, 12:12 PM   #3
That is a very common motor to find. Check farm supply,graingers,mc master/carr or any local motor shop.You do want capacitor-start,and the frame for mounting You may have to fabricate. Like to see people appreciate good machinery. Good Luck
antlerdancer is offline   Reply With Quote
Old 02-28-2010, 12:33 PM   #4
Idiot Emeritus
Ebay is a pretty good source for motors like this too.
The motor you want is one of the most common ones ever made, it'll be easy to find. The most common ones will be either a 48 or 56 frame size. The 48 frame has a 1/2" shaft, 56 is 5/8". Pulleys are usually available at hardware stores.
A split-phase or capacitor-start will work well, a PSC (Permanent Split Capacitor) might not have enough starting torque.
It'll likely cost a bit more, but a TEFC (Totally Enclosed Fan Cooled) one will last a lot longer than an open one will around sawdust.
If you need help hooking it up, post in the electrical section, there's about a dozen of us around there who can walk you through it.
Rob
micromind is offline   Reply With Quote
Old 02-28-2010, 01:36 PM   #5
Thanks!
Restoring bathroom wall and ceiling to put my house up for sale sturmnacht Interior Decorating 10 08-05-2009 11:05 PM
JakHof, and restoring a 100 year old German Farmhouse JakoftheHof Introductions 2 08-04-2009 09:17 AM
Wiring a bandsaw woodjammer153 Electrical 2 10-05-2008 11:50 PM
where to buy Renewal Wood Floor Restoring System Helen Herring Flooring 3 06-23-2008 10:34 PM
rigid bandsaw jud Tools 3 01-23-2008 12:26 PM
