Rest In Peace, Tablesaw - Tools - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 11:02 PM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 682
Rest in Peace, Tablesaw
My tablesaw was an inherited late 1940s Craftsman that was my grandfathers. it worked, but needed a new motor to keep from burning my house down. I replaced the motor with a craigslist find last winter. 2 days ago I went to rip down a board and received the bad news. The motor spun at about 4 (yes, four) rpm for 5 seconds, then popped the breaker. I took all the load off the motor and got the same result. I don't know what happened between the last time I used it and Sunday, but it's gone.
So, I could spend another $100ish (or more) for a new motor again, keeping this 7-1/4" table saw around, which can only rip up to 10" in the current form, or start new. I am just getting into woodworking, and didn't realize how much I depended on this saw for things. I don't have a dedicated woodshop, so a nice big shop saw is not an option. Looking more into the portable/jobsite style of saws so I can use it, then put it away and put my truck back in the garage.
I have twins on the way, so spending a fortune is also not an option for a rookie DIY/woodworker. Any suggestions on a new saw that is not insanely priced? I've been checking Craigslist, but so far I'm not impressed by anything.
hyunelan2 is offline   Reply With Quote
Old 03-29-2011, 11:13 PM   #2
Learning by Doing
Leah Frances's Avatar
*moment of silence for a good tool that served long and valiantly.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
Mop in Hand (04-13-2011)
Old 03-30-2011, 07:03 AM   #3
kwikfishron's Avatar
Rewards Points: 84
You need to elaborate on “insanely priced”. what’s your budget?
Are you just ripping small boards or do you need to be able to rip a sheet of plywood in half?
I see the cheap deltas for a $100 all the time, upgrade the blade and that’s all you should need for light duty use. It won’t rip a sheet of plywood in half though.
kwikfishron is online now   Reply With Quote
Old 03-30-2011, 07:11 AM   #4
DIY staff
Rewards Points: 7,174
How far south are you?---I've got two 10" sears table saws --both working--to give away.
They are big--double wings.
I live near St.Charles.---PM me if it's worth the trip.----Mike---
Old 03-30-2011, 07:39 AM   #5
hyunelan2's Avatar
Rewards Points: 682
PM coming oh'mike
FWIW, I was looking at saws in the $200ish range. I would like to be able to rip down plywood. This one that I saw (just started my search) was fairly portable, $200, and can right-rip 30". (I'm not sure why you'd need to go beyond 24 though).
http://www.sears.com/shc/s/p_10153_1...62000P?prdNo=6
Old 03-30-2011, 06:34 PM   #6
Rewards Points: 79
I've got the Ryobi version of that saw and it's a nice little saw. Probably not the best but I've used it for a lot of things around the house....
Ripped many boards for trim
Cut plywood for my workbench
Cut plywood for my first cabinet
Cut plywood for a shelf I made my wife.
I'm sure there are a lot of negatives in it but for me, a beginner and a light user it works great. Just measure twice and you should be fine.
itguy08 is offline   Reply With Quote
Old 03-31-2011, 11:52 AM   #7
timmymcg's Avatar
Send a message via Skype™ to timmymcg
Mike, I'm a newb so I can't PM, but I'm also a new homeowner (closed two weeks ago) with some good-sized projects coming up this summer. If you're still offering, I can offer great karma (and hand-delivery from Half-Acre, Revolution Brewing, or Three Floyds'--if that's your thing!).
Thanks, from a guy in need,
Tim
timmymcg is offline   Reply With Quote
Old 03-31-2011, 03:38 PM   #8
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 690
I think it would be better if Mike could load one on a keel boat and send it down the Mississippi to Vicksburg where I will quickly load it in my truck.
WirelessG is offline   Reply With Quote
Old 03-31-2011, 04:09 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Try a BIGGER motor. Couple horse power, 30,000 RPM. Rip a sheet of plywood like you were chopping cheese with a hot butcher knife.
Old 03-31-2011, 04:52 PM   #10
timmymcg's Avatar
The last two posts have me envisioning either the steam engine from a paddlewheeler belt-driving a 7 1/4" table saw.... Or a big ol' 'lectric motor pushing a paddlewheeler down the Mississippi.
Old 04-01-2011, 06:50 AM   #11
DIY staff
Tim
Be patient---The OP is taking both----Do stick around,however,good things come along----A table saw is the most important tool in the wood shop--
When you can PM--PM me---Mike---
timmymcg (04-01-2011)
Old 04-01-2011, 07:14 AM   #12
very generous mike, more like you would make this a smoother world to live in
The older I get the better I was
Old 04-01-2011, 07:23 AM   #13
DIY staff
Thanks----I just want them to go to someone who will use them safely.
They paid for themselves years ago-----
Old 04-06-2011, 08:27 PM   #14
DIY staff
Old saws are off to a new home!---Nice to think that they will be back in action!----Mike----
Old 04-07-2011, 04:29 PM   #15
hyunelan2's Avatar
Rewards Points: 682
Just wanted to publicly say thank-you to Mike for the new saws. I got one of them cleaned-up and assembled before work this morning. Fired right up. Just need to do some minor cleaning with the wire brush on the tops, replace an electrical cord, and I'm all set.
The Following User Says Thank You to hyunelan2 For This Useful Post:
oh'mike (04-08-2011)
mobile base for tablesaw Twink Tools 2 01-04-2011 09:36 AM
Fixing Leg Rest Bar - Chairs ddzc General DIY Discussions 0 11-27-2010 12:14 PM
Painting Foot Rest On A Bar glenn71x Painting 7 08-30-2010 07:13 AM
Lots of 2 inch thick maple to cut. What kind of tablesaw? kerryk Carpentry 3 08-09-2010 07:33 AM
Motor control box Sears Tablesaw rcamp50 Electrical 12 12-09-2007 04:45 PM
