Replacement Ratchet/socket Case - Tools - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 11:03 PM   #1
replacement ratchet/socket case
When your nice, ahem , plastic socket set case breaks, what do you put your sockets and ratchets in?
The Craftsman tools held up nicely, but the plastic latches on that case did not. Duct tape is only lasting so long.
diyntn is offline   Reply With Quote
Old 07-12-2009, 11:58 AM   #2
Mine has a small hole where it was originally sealed with a zip tie when new, but now I just wrap a piece of #12 solid copper in it. Works perfect! Ben
swaterbenny is offline   Reply With Quote
Old 07-12-2009, 07:06 PM   #3
Custom Cabinet Maker
diy; :}:}:} When you figure that out Please tell me so I can fix mine
skymaster is offline   Reply With Quote
Old 07-13-2009, 06:29 PM   #4
Rewards Points: 264
Wink
Try Sears, they sometimes have the replacement boxes available to order.
I hate it when those fitted boxes break, it is a hassle. I will sometimes buy a small plastic box, put the sockets on rails and the handles/extensions in a tray. I have a 1/4" box, a 3/8" box, and a metric box.
7echo is offline   Reply With Quote
Old 07-16-2009, 01:07 AM   #5
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by diyntn View Post
.....The Craftsman tools held up nicely, but the plastic latches on that case did not.
There may be some but I've never seen a Craftsman case that has held up.
The tools hold up, but not the cases.
The pic shows the original Plastic case for my Craftsman Industrial drill. In my case the sliding latches still worked but the plastic hinges
after the first year, were Kaput . I used a bungee around the box until I finally found a compact replacement last month:
http://www.casesandmore.com/Flambeau...ml#ManuDetails
It holds everything shown including the speed control,but not the mud mixer bit. Maybe I was just lucky, because there is not a quarter inch to spare in any direction in the yellow Fambeau box.
Sorry for the drift
No help on ratchet cases
replacement ratchet/socket case-mudmixer.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-16-2009, 02:19 PM   #6
47_47's Avatar
Rewards Points: 76
I just get a small metal tool box and organize them all in one box.
47_47 is offline   Reply With Quote
Old 07-16-2009, 04:24 PM   #7
Tool Geek
PaliBob's Avatar
Thanks 47_47, you sparked my memory
In 1960 I had a six drawer mechanics tool box jammed with automotive tools (still have it) The top compartment held a removable tray for the 1/2" tools, but I had all the 3/8th tools jammed in one drawer. Bummer going back and forth to get the right size socket.
I solved it at the Hardware store in Venice CA by asking them to order a case. It took a month to get it, but I still have it. No plastic on these cases. Also available in different sizes. The Snap-On case fits nicely in the drawer.
I was surprised to see they look the same, Only in 1960 there was no color option from RED.
http://www.paddockclub.co.kr/snap/In...ebS/5/S501.htm
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-17-2009, 06:08 AM   #8
Years ago I got a socket set from Sears in a soft pack, elastic held everything in place. Handy set but........now the elastic is shot and i can't find a substitute. I hate to just have everything in a pile.
Old 07-17-2009, 06:14 AM   #9
47_47's Avatar
Rewards Points: 76
PaliBob,
When I was a tech, I cut a piece of 3/4" plywood to fit in the bottom drawer of my tool box (approx 36"x 18"). Screwed (2) drawer pulls and socket rails to the plywood and placed this set up in my tool box. Every morning, lift out the board and placed on a shelf.
If I needed to do a side job, place the tray on the back of the truck and work from there.
Old 07-17-2009, 12:03 PM   #10
Tool Geek
PaliBob's Avatar
Cool Solution
Disclaimer
& Stay Safe
.....Bob Lavery
Old 10-01-2011, 10:55 AM   #11
Lightbulb
what I have done is go to the wood workers supplies sites they have latches for wood boxes ( cigar, jewelry etc ) many, many styles and the costlier ones last a long time.
gepetto392 is offline   Reply With Quote
Old 10-15-2011, 06:04 AM   #12
thanks
It's a cheap way to get around the lousy engineering of Sears. And I am cheap but I hate to throw something away that can be saved. Thanks
Old 10-19-2011, 03:40 PM   #13
Too Short? Cut it Again!
I cannot single out Sears. Most plastic boxes, or especially their latches, don't last. When I need a case for something I shop for the right size to hold everything. I then get a piece of foam, wet it and freeze it. When frozen you can drill perfect holes or use a saber saw to cut out shapes. Thaw it out and you have a custom fitted foam insert to hold sockets, handles, or whatever.
Bathtub Spout Replacement cspirit Plumbing 4 03-18-2011 06:39 PM
Xbox original pc case mod...(in progress) rgsgww Off Topic 27 03-31-2009 06:54 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
replacement compressor needed for old GE rotolock alex977 HVAC 1 05-17-2007 07:36 PM
