Replacement Part For Roof Rake - Tools - DIY Chatroom Home Improvement Forum
Old 01-03-2016, 01:13 PM   #1
Solidify's Avatar
Rewards Points: 816
Replacement Part for Roof Rake
I have one of these snow roof rakes but lost one of the silver springs in the third section (surely in the snow) so I cant use the full length.
Where can I find a replacement piece like this?:
Solidify is offline   Reply With Quote
Old 01-03-2016, 01:15 PM   #2
Solidify's Avatar
Rewards Points: 816
I already tried using a bolt and screw but it comes undone very quickly and is a hassle to remove when I need to remove a section to shorten. I'd much rather find that part.
Old 01-03-2016, 02:15 PM   #3
Rewards Points: 976
If it isn't in the tube, consider a piece of all thread cut to length with a clip on each side. Knock the sharp edges and burrs off the ends so you don't hurt self. Or if You be real good a couple of grooves can be cut cut in a smooth bolt with a dremmel cut off wheel and round the ends so it looks purdy.
Old 01-03-2016, 02:34 PM   #4
griz's Avatar
Rewards Points: 570
http://www.grainger.com/category/sna...ecatalog/N-n3p
griz is offline   Reply With Quote
Old 01-03-2016, 07:09 PM   #5
Solidify's Avatar
Rewards Points: 816
Perfect. Do you know where I can buy that in person? Because the shipping cost will murder me sincd I'm in Canada. I checked HD but they don't seem to have them.
Edit: They don't even ship to Canada.
Old 01-03-2016, 08:31 PM   #6
griz's Avatar
Rewards Points: 570
Got a friend state side?
Old 01-03-2016, 09:51 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,002
Look for a Clevis pin. Should be readily available at any hardware store.
Old 01-03-2016, 10:32 PM   #8
joed's Avatar
Rewards Points: 12,334
Check out Canadian Tire. Product #40-6578-4, Master Lock Towing Pin Clips, 3-pk $2.99.
They also have this type. Product #40-6509-0
Old 01-04-2016, 08:22 AM   #9
Solidify's Avatar
Rewards Points: 816
I tried the towing pin clips but they were just too difficult to set in place, not to mention I'd need these extensions to come off easily while outside in subzero temperatures.
My roof rake still had 2/3 functional snap buttons so I took the lower one that never needs to be removed and replaced it with a bolt that I applied locktite to:
Old 01-04-2016, 09:14 AM   #10
Solidify's Avatar
Rewards Points: 816
I also filled down the end of the bolt to make sure the nut won't come off.
Old 01-04-2016, 09:44 AM   #11
ZTMAN's Avatar
Rewards Points: 322
Try Fastenal for the spring clips , they have three stores around Montreal
ZTMAN is offline   Reply With Quote
Old 01-04-2016, 10:13 AM   #12
Solidify's Avatar
Rewards Points: 816
Thanks I'll check it out.
Old 01-04-2016, 11:19 AM   #13
ZTMAN's Avatar
Rewards Points: 322
Just as an fyi, I thought I lost the same clip, but it turns out it was just pushed up in the pole. Take a flash light and look inside the pole.
Old 01-04-2016, 11:25 AM   #14
Rewards Points: 976
If he paid any attention to reply 3 he has been there done that.
Old 01-04-2016, 11:53 AM   #15
ZTMAN's Avatar
Rewards Points: 322
I missed that myself Senior, please accept my sincere apologies .
Trane Blower Wheel Replacement Part tripflex HVAC 1 10-08-2012 03:09 PM
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Replacement for ST9141A1002 chicagocane HVAC 0 11-23-2010 02:54 PM
replacement part for Aire-flo furnace? BlueBSH HVAC 9 09-14-2010 08:41 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
