Replacement Blade For B&D Mm525 Mower - Tools - DIY Chatroom Home Improvement Forum
Old 08-22-2011, 03:38 PM   #1
replacement blade for B&D mm525 mower
Hi,
I was given a black&decker electrical mower (mm525, type 4). It's missing the blade. I am trying to figure out what replacement blades are compatible. I am cheap so I don't want to buys a blade, instead I want to find a broken mower and cannibalize it. So it it just the length and the size and shape of the whole in the center that determine compatibility?
Thanks!
ilyaz is offline   Reply With Quote
Old 08-22-2011, 09:57 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Sure. if it's a 19" blade with the same center hole it should fit. because it's an electric mower you'll probably need a thin, lighterweight blade than one used for a gas engine.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-25-2011, 06:30 AM   #3
kwikfishron's Avatar
Rewards Points: 762
Originally Posted by ilyaz View Post
Hi,
A new blade is less than twenty bucks but you probably already knew that.
kwikfishron is online now   Reply With Quote
Replacement Condensor Fan blade pitch? daviesow HVAC 13 05-11-2015 09:17 PM
Sharpening mower blade RDS Landscaping & Lawn Care 20 04-09-2012 09:49 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Guy borrowed my mower Hamsor Off Topic 20 08-08-2010 10:52 AM
Dethatch blade for walk behind mower? ferris13 Landscaping & Lawn Care 3 04-13-2010 11:32 AM
