-   Tools (http://www.diychatroom.com/f29/)
-   -   replacement blade for B&D mm525 mower (http://www.diychatroom.com/f29/replacement-blade-b-d-mm525-mower-114898/)
ilyaz 08-22-2011 04:38 PM
Hi,
I was given a black&decker electrical mower (mm525, type 4). It's missing the blade. I am trying to figure out what replacement blades are compatible. I am cheap so I don't want to buys a blade, instead I want to find a broken mower and cannibalize it. So it it just the length and the size and shape of the whole in the center that determine compatibility?
Thanks!
Mr Chips 08-22-2011 10:57 PM
Sure. if it's a 19" blade with the same center hole it should fit. because it's an electric mower you'll probably need a thin, lighterweight blade than one used for a gas engine.
kwikfishron 08-25-2011 07:30 AM
Originally Posted by ilyaz (Post 712915)
Hi,
A new blade is less than twenty bucks but you probably already knew that.
