Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 10-19-2008, 02:32 AM   #1
Default Replace miter gauge of B&D table saw
I have a Black & Decker table saw, model FS210LS. I need a replacement for the miter gauge. And here I run into problem.
Miter gauges for sale on the net are for standard size 3/4" x 3/8". I am not sure my table saw's guiding slot is of that size. The depth of the slot is not quite 3/8 and the slot width is not quite 3/4".
B&D web site has no contact email to ask. The manual does not specify the miter gauge dimension. Thus I am hesitant to buy just any miter gauge for fear it won't fit.
Then I found a website eReplacementParts.com which have replacement for B&D miter gauge.
The link below shows diagram of the table saw parts:
http://www.ereplacementparts.com/bla...tegory=FS210LS
It shows the miter gauge (part #25) as "miter gauge assembly". I am not quite sure "miter gauge" and "miter gauge assembly" are the same or not, but it looks like it, so I ordered it. Then they send me something entirely different (a thick metal ring). It could be their mistake or my bad for ordering the so-called "miter gauge assembly". I'm dealing with eReplacementParts.com right now.
Meanwhile, I turn to the pro and the know-hows on this forum to help: how do I best find a replacement for my miter gauge?
Thank you.
Nathan
nathan.tran is offline   Reply With Quote
More On This Topic
We will cut the side pieces and front piece down to thirteen inches wide, and to do so we must reinstall our miter gauge by removing the rip fence. This time however, the miter fence must be turned to ninety degrees. I must measure them to thirteen... Read More »
Anatomy of a Table Saw
Anatomy of a Table Saw by Expert Village
In this clip, we're going to talk a little bit about the anatomy of the table saw. Now we touched on the overall purpose so now let's talk about what each piece is. I'm going to remove the guard just to show you the blade. This is a carbide tipped... Read More »
Hi! I’m Rob McMahon for Expert Village. Now, although ripping is primarily what you’ll do with your table saw, you can also perform cross cuts with a miter gage. This saw has one that's stowed on board. Remove our fence and set that right on... Read More »
How to Remove Fog Lights
How to Remove Fog Lights by Expert Village
Hi, my name is Nate McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to diagnose and replace your vehicle's fog lights or accessory lights. In this clip we're going to talk about dismounting or remounting... Read More »
Okay, let's start by marking off our wood board here. We need 2, two and a half inch sections, so I'm measuring two and a half inch, I'm going to draw a line and again two and a half inches. So I have one, two; two and a half inch sections, and then one... Read More »
miter saw 45 Deg how too turn table? chinese_lover Carpentry 9 07-22-2008 10:58 PM
Need Advice for Adding Wheels to Table HandyDottie Carpentry 7 01-27-2008 09:44 PM
12 gauge wire to 14 gauge on an outlet question diyer4162 Electrical 35 12-20-2007 02:55 PM
Plans for a miter saw table jparker45 General Discussion 3 12-15-2007 07:54 AM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 10:47 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
