Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 03-14-2011, 12:59 AM   #1
Removing spark plug on Paslode Angled nailer
My Paslode gun is not firing, when I pull the trigger the fan spins, I smell gas and hear a psssst sound, but no ignition.
I cleaned the gun as per maintenance instructions, and I can see the round piece on the back that houses the spark plug, but I cannot access the plug, I do not want to use force.
Can anyone give me detailed instructions on how to remove the spark plug so I can either clean it or replace it.
solarant is offline   Reply With Quote
Old 03-14-2011, 02:24 AM   #2
Its behind the air filter. Take the air filter cover off with an allen wrench. Pull the spark plug wire off the spark plug. It's a thick red wire with a rubber boot(on mine it was). A half turn loosens the plug. Replace it with a new one. Your good to go. I got a tune up kit that came with a spark plug at a local tool supply for about $20. I would recommend the kit. It came with a couple other things too, oh, and instructions.
SoCalLivin is offline   Reply With Quote
Old 03-14-2011, 07:15 AM   #3
Make sure the gas is fresh, it has a shelf life. I had a similar problem, would not fire consistently. Same problem after cleaning and tune up. Installed new gas cartridge, works fine.
Old 03-14-2011, 01:24 PM   #4
I just bought new cannisters of gas still the problem persists
Old 03-14-2011, 01:26 PM   #5
The round cover for the spark plug just turns and when I tug on it there is no give, as I said I do not want to force it, I think there might be a retaining clip holding it, but from what I can see there is no way to get this clip off.
Old 03-14-2011, 05:08 PM   #6
Huh, my gun is the IMCT and thats how I did it. You can always email paslode (tech@paslode.com), or call em (800-222-6990). Maybe your gun is designed a little different, I dont blame you for not wanting to force it.
Paslode pneumatic finish nailer Ken101 Tools 9 10-23-2011 09:55 AM
Finally purchased a my paslode Angled finish nailer gmhammes Tools 4 02-28-2011 10:40 PM
Paslode framing nailer TJH Tools 1 12-13-2009 01:55 PM
Looking for a 16g angled finish nailer... Goldglv Tools 15 07-26-2009 04:02 AM
Paslode framing nailer sparks Richo Tools 1 03-10-2009 05:43 AM
