-   Tools (http://www.diychatroom.com/f29/)
-   -   Removing spark plug on Paslode Angled nailer (http://www.diychatroom.com/f29/removing-spark-plug-paslode-angled-nailer-98306/)
solarant 03-13-2011 11:59 PM
My Paslode gun is not firing, when I pull the trigger the fan spins, I smell gas and hear a psssst sound, but no ignition.
I cleaned the gun as per maintenance instructions, and I can see the round piece on the back that houses the spark plug, but I cannot access the plug, I do not want to use force.
Can anyone give me detailed instructions on how to remove the spark plug so I can either clean it or replace it.
SoCalLivin 03-14-2011 01:24 AM
Its behind the air filter. Take the air filter cover off with an allen wrench. Pull the spark plug wire off the spark plug. It's a thick red wire with a rubber boot(on mine it was). A half turn loosens the plug. Replace it with a new one. Your good to go. I got a tune up kit that came with a spark plug at a local tool supply for about $20. I would recommend the kit. It came with a couple other things too, oh, and instructions.:thumbsup:
Just Bill 03-14-2011 06:15 AM
Make sure the gas is fresh, it has a shelf life. I had a similar problem, would not fire consistently. Same problem after cleaning and tune up. Installed new gas cartridge, works fine.
solarant 03-14-2011 12:24 PM
I just bought new cannisters of gas still the problem persists
solarant 03-14-2011 12:26 PM
The round cover for the spark plug just turns and when I tug on it there is no give, as I said I do not want to force it, I think there might be a retaining clip holding it, but from what I can see there is no way to get this clip off.
SoCalLivin 03-14-2011 04:08 PM
Huh, my gun is the IMCT and thats how I did it. You can always email paslode (tech@paslode.com), or call em (800-222-6990). Maybe your gun is designed a little different, I dont blame you for not wanting to force it.
