Regular Sawzall Vs Orbital Sawzall - Tools - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 09:13 PM   #1
Rewards Points: 258
regular Sawzall vs Orbital Sawzall
I was looking at Milwaukee's Sawzall's. I saw a 12 amp for $99 and a 12 amp orbital one for 149.
Whats the difference?
jburchill is offline   Reply With Quote
Old 12-08-2011, 11:17 PM   #2
Oldguy
Rehabber's Avatar
If you use a Sawzall as hard as I do, you will appreciate the orbital action when cutting larger or tough materials, the ability to choose the stroke is a real plus for me.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-09-2011, 09:35 AM   #3
Rewards Points: 502
the blade path I think. 1 is linear, and the other move in an orbital path. it should be more aggressive, and probably vibrate a bit less if I had to guess. I never tried one.
forresth is offline   Reply With Quote
Old 12-09-2011, 09:39 AM   #4
Rewards Points: 258
I'm not planning on using one everyday, but there are times when I need one and then have to borrow someones...is 50 bucks extra worth it if I'm not gonna use one all the time?
Old 12-09-2011, 11:25 AM   #5
Ironlight's Avatar
No it's not worth it for occasional use. Orbital action cuts a bit faster, but is only good for straight line cutting. A cut that takes 12 seconds with a regular sawzall will take 9 seconds with orbital action.
I have the $99 Milwaukee. Used it extensively during my current renovation. Thought I would use it only now and then but it is a much more versatile tool than I had expected and I have used it a lot. But even so the one I bought is more than I need most times. It's a beast.
Ironlight is offline   Reply With Quote
Old 12-09-2011, 05:00 PM   #6
Civil Engineer
Rewards Points: 4,942
I have the orbital version, bear in mind it can be used either as orbital or straight line cut. As noted, the orbital is faster, but the most important factor in speed of cut is having a sharp blade. I usually use orbital when doing demolition work on tough boards with nails, most of the time I use straight line action, easier to control the cut. I too have found the Sawzall to be very useful for a wide range of projects, but it seems to be an absolute necessity on framing demolition work. I can't imagine doing the demo work for my exterior French doors or the demolition of a load bearing wall between kitchen and dining room without it. As for the extra $50, it isn't that much money in the big scheme of things, could be worth it, I certainly think it was, but consider I am amortizing this tool over at least ten years.
Old 12-09-2011, 07:43 PM   #7
In a little over my head
Rewards Points: 706
I just bought that $99 Milwaukee to replace a Ryobi that still worked, but had a cranky blade clamp. The red saw runs circles around the blue one. No regrets at all. Save the $50 for your next tool.
ratherbefishing is offline   Reply With Quote
Old 12-10-2011, 06:42 AM   #8
And a super sawzall adds a anti vibration counterbalance which works quite well saving your hands the vibration!
toolaholic is offline   Reply With Quote
Old 12-11-2011, 07:46 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
one thing that no one has stated is that the orbital action is for cutting wood only,, do not use it for cutting metal such as nails. for cutting metals run it on straight cut mode
woodworkbykirk is offline   Reply With Quote
Old 12-16-2011, 07:29 PM   #10
Ironlight's Avatar
That's an incredibly important point. Most of what I use my sawzall for is pretty limited....a 10-15 second cut and for that it has been great. but I have done a few longer cuts with it and the vibration is really noticeable in the $99 model. If you're going to be doing numerous longer cuts then I can see the anti-vibration feature of the super being a real arm saver.
Old 12-17-2011, 01:06 PM   #11
raylo32's Avatar
Rewards Points: 1,294
Definitely agree with this. Not an issue for occasional light use but for frequent or heavy use vibes can be a real problem. I used my Dewalt for cutting some 6x6 treated posts while building a deck a few years ago and my hands weren't right for a couple days after. That thing really beat them up.
raylo32 is offline   Reply With Quote
Old 12-17-2011, 03:08 PM   #12
that sounds about right for a dewalt.. their recips are one of the worst.. underpowered and they burn out easily..
the makita avt and the milwaukees are the best ones available. i hear bosch makes a decent one also but still have yet to try one
Old 02-11-2015, 03:40 PM   #13
Rewards Points: 2
Thumbs up
Great info and things to consider
Great thread. I learned a few things and thought about a few things I hadn't even considered. Thanks for sharing your knowledge.
tranzicion is offline   Reply With Quote
Old 02-11-2015, 03:50 PM   #14
Gymschu's Avatar
Rewards Points: 1,024
+1 on Milwaukee.
20 years ago, when I was a new homeowner, I splurged on a Milwaukee Sawzall. At the time I think it was $150 and it was a time in my life when I didn't have $150 to spend like that. It was the best investment I ever made in a tool. I have used that thing countless times over those 20 years on many a home improvement project. It has never let me down. Great tool.
Giving us your general location helps us better help you!
The Following User Says Thank You to Gymschu For This Useful Post:
PaliBob (02-11-2015)
Old 02-11-2015, 06:21 PM   #15
the other thing not mentioned about using orbital action is that it can actually clear the kerf of saw dust quicker..
and you will notice a drastic difference in the cutting speed both with upping the amperage and using orbital. i own a 15 amp milwaukee that has the orbital option along with a 9 amp makita. the makita feels like a toy in comparision. similarly one of my guys has a 10 amp milwaukee that only has straight cut and its considerably slower
its comparible to using a impact driver to drive large screws compared to a drill driver in the high speed setting..
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
Gymschu (02-11-2015), PaliBob (02-11-2015)
regular vent pipe->type B adapter amakarevic HVAC 2 11-03-2011 01:35 PM
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 08:33 PM
Random Orbital Sander Suggestions (<$100) hyunelan2 Tools 11 03-28-2011 07:49 AM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 03:26 PM
Happy Halloween - Look what you can do with A Sawzall jamiedolan Off Topic 5 11-13-2008 10:26 AM
