Recommendations On A Small Pump For Water - Tools - DIY Chatroom Home Improvement Forum
Old 09-26-2008, 09:06 AM   #1
Rewards Points: 101
I have one of those inflatable pools in my yard that I'll be draining and taking down. I wanted to pick up a submersible pump to drain the water. Everything I've seen online seems to be expensive sump pumps that are meant to be used regularly. I wanted something for occassional household use. Any suggestions?
jte1130 is offline   Reply With Quote
Old 09-26-2008, 09:19 AM   #2
the Musigician
DangerMouse's Avatar
perhaps you could save the money and just use a garden hose and siphon it out? or if you don't care where the water goes, just let the air out?
DM
Old 09-26-2008, 09:25 AM   #3
Harbor Freight Pump
I've had good luck with these from Harbor Freight, you can often catch them on sale. http://www.harborfreight.com/cpi/cta...emnumber=45014
jrepp is offline   Reply With Quote
Old 09-26-2008, 10:50 AM   #4
Rewards Points: 101
Thanks jrepp. Thats exactly what I'm looking for and the price is right.
GFCI problem with pond pump sandsmarc Electrical 21 04-05-2013 01:51 PM
Small condo, appliance cost recommendations Snowy334 Interior Decorating 1 08-12-2008 07:17 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-08-2006 11:42 PM
