Recommendations For Battery Jump Pack - Tools - DIY Chatroom Home Improvement Forum
Old 04-03-2013, 12:40 PM   #1
Rewards Points: 121
Recommendations for Battery Jump Pack
I am looking for a Battery Jump Pack, mainly to power a 12v dc chemical sprayer, but to also jump start a pickup truck. I see some have a built in air pump and 110v ac inverter. Any suggestions would be welcome.
jrepp44 is offline   Reply With Quote
Old 04-03-2013, 04:36 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I don't have a Battery Jump Pack but I would probably pick this one
or this one with extra features.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 04-03-2013, 05:19 PM   #3
Bill Kearney
Rewards Points: 1,174
Eh, I've got the Harbor Fright 5-in-1 and it's not really all that great. Yeah, if your battery is only just barely too low it'll help. But not if it's dead or very low, trust me. The inflator is likewise effective. Good if your tire is low but not if it's flat. If that's good enough for you then the 5-in-1 is a decently priced solution. Just be careful about charging it, their included wall wart transformer does not trickle charge reliably. Ignore it and leave it charging too long and you'll ruin the gel cell inside.
wkearney99 is offline   Reply With Quote
Old 05-04-2014, 06:19 PM   #4
Rewards Points: 1,680
Recommendation For Battery Jump Pack & Portable Tire Inflator
I drive a '94 F-250 5.8 L Gas. Tires:LT235/85R16/E
Grateful for recommendations, from experience if possible, for Battery Jump Pack and Portable Tire Inflator.
justplumducky is offline   Reply With Quote
Old 05-04-2014, 06:46 PM   #5
In a little over my head
Rewards Points: 706
I've had good luck with the Jump-n-Carry. Built in automatic charger. Don't bother with any other built ins. It's a lead acid battery, so keep it charged. If you tote it around in your trunk, it'll be dead when you need it.
ratherbefishing is offline   Reply With Quote
Old 05-05-2014, 11:23 AM   #6
I would look at the required electrical requirements for the spayer and what length of time you need to run it.
Are you taking the spayer a good distance from vehicle? Any information on the sprayer?
Focused2 is offline   Reply With Quote
Old 05-06-2014, 08:53 PM   #7
Rewards Points: 706
A deep cycle battery may work better for the sprayer.
The Following User Says Thank You to ratherbefishing For This Useful Post:
DH558 (05-10-2014)
Old 05-10-2014, 08:15 AM   #8
Hogger
I have one of these from Stanley, has worked great in the 10 months that I've owned it:
http://www.lowes.com/pd_366125-89606...ductId=3579488
DH558 is offline   Reply With Quote
Old 05-10-2014, 09:39 AM   #9
landfillwizard's Avatar
Rewards Points: 516
I your sprayer affixed to your vehicle or is it portable?
landfillwizard is offline   Reply With Quote
Old 05-19-2014, 03:49 PM   #10
Rewards Points: 121
Hi everyone, I am the original poster from 2013. Thanks to "justplumducky" for resurrecting this thread. My sprayer is a 15 gal unit that I tow behind my golf cart. I ended up purchasing a battery pack from Sears with a 12v outlet. It runs the small 12v DC Shurflo pump just fine. Just remember to drain the pump for the winter - or you will be buying a new one in the spring
recommendations for beverage centers? bbo Appliances 0 02-11-2012 03:04 PM
Netting selection for dense pack cellulose crankcase Insulation 3 09-10-2011 07:41 AM
Heil Gas Pack Burner Issue Howard99 HVAC 14 12-04-2010 06:30 AM
Make the jump to tankless? Recommendations? acerunner Plumbing 8 09-26-2010 09:27 PM
Help with gas pack trunk sizing justinNC HVAC 3 10-31-2009 08:38 PM
