Recommendation For A Miter Saw - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 12:02 PM   #16
Rewards Points: 512
the ridgid 10" dual bevel saw comes stock with a freud diablo blade.
http://www.ridgid.com/Tools/MS255SR-...w/EN/index.htm
princelake is offline   Reply With Quote
Old 09-22-2012, 01:15 PM   #17
journeyman carpenter
woodworkbykirk's Avatar
home depot has a deal with freud where freud is the primary brand of blade they sell, since ridgid is exclusive to hd freud blades go on the saws
woodworkbykirk is offline   Reply With Quote
Old 10-02-2012, 02:38 PM   #18
Rewards Points: 5,974
I have the Ridgid 12" with their stand and I like it a lot. My neighbor has the Dewalt with their stand. The big advantage with the Ridgid over the Dewalt is the Ridgid fastens to the stand and can be left mounted there and their stand has wheels so it's easy to move. The Dewalt has to be removed from the stand every time you move it or you need a friend to help carry it.
Old 10-02-2012, 05:42 PM   #19
yah. the ridgid stand is handy in that sense but makes loading the tool a 2 man job as the stand alone is almost 70 lbs.. add the weight of a saw too and your over 130lbs depending on saw model. i have a bosch 12" on the rigid stand
dewalt now has a stand similar to the ridgid and bosch axial glide but not as good a design.. and yet still costs more than most other stands....as for saws stick to the proven 3. makita, bosch and the milwaukee..
Old 10-02-2012, 11:21 PM   #20
Makita 1013 10" sliding saw if you are happy with a decent to good quality saw and a Festool Kapex if you want the best of the crop.
riddlers is offline   Reply With Quote
Old 10-03-2012, 09:54 AM   #21
My friend has the Bosch 12" slider and he has had quite a bit of trouble with the fence. But he has had it for quite a while now so hopefully they have that problem solved or maybe he just got a bad one it happens.
Old 10-03-2012, 04:02 PM   #22
it depends on how often its transported and handled while doing so. if its just thrown in the truck or van it will get knocked out of alignment. ive only had to adjust mine once and that was after 4 years of service getting ready for a stain grade trim package throughout a full house .the saw merely needed a shot of lithium spray lubricant more than anything
Old 10-07-2012, 01:58 AM   #23
Rewards Points: 30
I've narrowed it down to two saws now. Which is the better one to go with.
10" Double Bevel Sliding Compound Saw
Bosch 4310 (no stand - purchase separately)
Dewalt DW717 (there is a promo for the free DW723 heavy duty stand now)
I'm more concerned about the performance and the ability to give accurate cuts.
I plan to buy the saw early to mid next week. Hope to hear your thoughts by then.
sleong is online now   Reply With Quote
Old 10-07-2012, 06:36 AM   #24
DIY staff
Rewards Points: 7,174
I've got the DeWalt ---A little disappointing---poor sight lines---and early failure of the head tilt stops---
Still a good useable tool----but I think the Bosch might be the better choice.
Old 10-07-2012, 06:49 AM   #25
I haven't bought dewalt in a dozen years. I have their drywall gun from the 90s and a sidewinder circ from the 90s that is made in USA. I think the circular is model 953. Their newer stuff just hasn't tripped my trigger.
toolaholic is offline   Reply With Quote
The Following User Says Thank You to toolaholic For This Useful Post:
oh'mike (10-07-2012)
Old 10-07-2012, 08:46 AM   #26
Although it is very expensive. I would suggest checking out the festool kapex saw before you make a decision. It is a "do everything" saw. Just change the blade and you can go from cutting framing to stain grade crown in minutes. Love everything about the saw. HD mine for 3 years
robs660 is offline   Reply With Quote
Old 10-07-2012, 10:21 AM   #27
Rewards Points: 512
festools saws are vvvery expensive and i dont even look at that.
ridgid is probably the best bang for your buck.
bosch is a little pricey but you get what you pay for.
Old 10-07-2012, 10:23 AM   #28
Wow if he's just putting trim up around the house and stuff for himself talk about sticker shock your going to put him in the hospital.
Old 10-07-2012, 11:31 AM   #29
Rewards Points: 30
Festool is too expensive and out of my reach. I know they are a good saw but really how many times in a year will I pull it out to make cuts? Probably not enough to make it worth while to invest in that!! I'm just the typical DIY guy.
Well between the Dewalt and Bosch one is made in Taiwan and the other Mexico. Whether this matters or not in quality.
Bosch I'd have to spend an extra $200+ for a stand and the Dewalt includes a stand till the end of the month.
Maybe I may look at Rigid as princelake noted.
I've had a few Dewalt tools but no issues with them so far.
Old 10-07-2012, 11:50 AM   #30
For what you are going to use it for I think any of the ones you are looking at will be a good choice just decide whice one has the bells and whistles you want and go for it. About where they are made, as sad as it is to say, all power tools are made overseas now if i'm not mistaken (possible) the last one to leave was Porter Cable.
Hitachi vs Dewalt Miter Saw cstrasz Tools 12 03-11-2012 06:55 PM
miter bar problem ChrisMohrSr Carpentry 2 02-06-2011 09:47 PM
miter saw recommendation amakarevic Building & Construction 19 08-03-2007 03:00 AM
Need advice or feedback on miter saws mwehnes Carpentry 10 02-21-2007 09:48 AM
Looking for a Miter saw recommendation alvanos Tools 4 01-05-2006 11:18 PM
