Recommend A Good Stud Finder. - Tools - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 03-27-2016, 11:19 AM   #1
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Recommend a good stud finder.
What is the best you have found. Anything that will work through plaster and wood lath? Would like to keep under $50.
Coastal South Carolina
Old 03-27-2016, 05:55 PM   #2
Rewards Points: 13,270
Re: Recommend a good stud finder.
No electric stud finder is going to work with plaster and lath.
It's not going to know if it's a stud or the lathe.
A cheap magnetic one would find the nails.
Fixif likes this.
Old 03-27-2016, 06:15 PM   #3
DIY staff
Rewards Points: 7,174
The best stud finder I have is a Franklin---it has a row of sensors and a row of lights--
Well worth the cost---
However, I think Joe is right about using a stud finder on an old lath and plaster wall-
A magnet on a string might be more successful.
Old 03-27-2016, 09:48 PM   #4
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 818
I've got a Zircon rebar detector that works great on studs. Also works well on rebar in concrete and CMU, and for finding the buried steel receivers in a baseball infield for the base mounting posts.
Aggie67 is offline   Reply With Quote
Old 03-27-2016, 10:49 PM   #5
Rewards Points: 310
Best thing for you is a 1/8 drill bit and some spackle. Knock on the wall until you can hear some variant in thud...then drill a few small holes until you get resistance from a stud. Magnet stud finder is best for drywall situations...never misses.
PandJ is offline   Reply With Quote
Old 03-28-2016, 05:42 AM   #6
A "Handy Husband"
rjniles's Avatar
Mike, is that the Franklin 710? Seems to have very good reviews.
Old 03-28-2016, 07:30 AM   #7
Property Mgt/Maint
Rewards Points: 718
one vote for knuckle and small drill, I do have a zircon that collects dust (somewhere)
Yodaman is offline   Reply With Quote
Old 03-28-2016, 08:19 AM   #8
Rewards Points: 692
For those in a hurry a sewing needle or straight pin pushed with pliers is much faster at locating studs than a drill bit and the holes need no filling except for paint if at all.
Old 03-28-2016, 08:30 AM   #9
DIY staff
I don't remember the number---I bought one last year and my assistant kept sticking it into his tool box--last week I bought another one for my truck.
Cost a little more than $35.00 at the local Menards.
Once you use one you will never be happy with the old style stud finder.
Old 03-28-2016, 09:21 AM   #10
http://www.homedepot.com/p/C-H-Hanso...B&gclsrc=aw.ds
Old 03-28-2016, 11:21 PM   #11
Msradell's Avatar
Rewards Points: 122
I've got this one: http://www.homedepot.com/p/Zircon-Mu...6230/205224990 and I found it will work quite well through plaster and wood lathe. It also does quite well at detecting live electrical wires within the walls.
Written using Dragon Naturally Speaking
Msradell is online now   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
rjniles (03-29-2016)
Old 03-29-2016, 04:50 AM   #12
Rewards Points: 820
The best "Stud Finder" that I have ever found is the "Franklin ProSensor 710"
(Interestingly, it does not seem to be affected by "false readings" from power cables etc.)
While I have never had the need to use mine on a "lath and plaster" construction, I would envisage that, if you used it vertically, it would show every lath and in the horizontal direction it would show every stud.
Interestingly, on http://slickdeals.net/f/7024596-prof...-prosensor-710 there are "instructions for the "Profinder 5000" which appears to be the same device.
Therein it states: -
"Lath and Plaster
Irregularities in plaster thickness and variations in construction materials can make it difficult to locate studs behind lath and plaster walls. Also, if the plaster has a mesh reinforcement, the stud finder may not be able to detect through the metal mesh. Although many users have success with the ProFinder 5000 on lath and plaster walls, there is no guarantee the ProFinder 5000 will work on all lath and plaster walls."
At $35, you could "give it a try" and let us all know how you go!
FrodoOne is online now   Reply With Quote
The Following User Says Thank You to FrodoOne For This Useful Post:
Old 03-29-2016, 06:46 AM   #13
Rewards Points: 113
I have a Franklin and it's fantastic. I have had many others and they don't compare to the franklin.
christoff is offline   Reply With Quote
The Following 2 Users Say Thank You to christoff For This Useful Post:
oh'mike (03-29-2016), rjniles (03-29-2016)
Old 03-29-2016, 03:36 PM   #14
Oso954's Avatar
Rewards Points: 746
Best one I ever used, wish I could find one today.
Oso954 is offline   Reply With Quote
Old 04-02-2016, 07:50 PM   #15
Property Mgt/Maint
Rewards Points: 718
Just yesterday I needed to find the rafters behind 5/8 drywall in a cathedral ceiling.
With this telescoping magnet I was easily able to pick up 2 dozen drywall screws in just a few minutes.
If I were ever in the market for a actual detector I would want one with a magnet as means of detection
Best size and shape of magnets to use as stud finder? Studly Remodeling 2 03-05-2015 06:03 AM
Attempting to be a good DIY Chatroom member sore thumb General DIY Discussions 16 07-16-2013 12:16 AM
Stud finder and lead based paint? thunderhead Electrical 1 07-24-2011 07:49 PM
Recommend me a good Garbage Disposal BlueBSH Appliances 6 01-09-2010 10:12 PM
Is it safe to remove this stud? lofar Remodeling 4 06-17-2009 12:22 AM
