Random Orbital Sander Suggestions (<$100) - Tools - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 07:14 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 690
I'm in the market to buy a random orbital sander. Currently I have a detail finish sander and a belt sander - I need to get something to fill the in-between. The number one project for this will be to redo the finish on my deck. After that, there is always something I am building/refinishing/etc that a random orbital would be useful for having.
In my one-night of looking around, I've seen some nice ones that were feature loaded, but way over what I'd currently like to spend. I also have some questions in the following areas:
  • 2.0a vs. 3.0a
  • importance of variable speeds?
  • 5" vs. 6" (though in this price range there aren't many 6").
Obviously I could go with the bigger/more is better strategy, but I don't want to over-buy and get a $100 sander when a $40 would do.
Some things I was considering:
Hitachi SV13YB $40/reconditioned 2.0a, single speed
Dewalt d25451K $59 3.0a, single speed
Bosch ROS20VSK $62 new 2.2a, vairable speed
My last 3 powertools were from those 3 brands, and I like them all about equally, but am not a brand-snob and have no loyalty to any of those. I'd consider any and all other suggestions too.
Thanks!
hyunelan2 is offline   Reply With Quote
Old 03-24-2011, 08:22 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
  • 2.0a vs. 3.0a
Thanks!
The three you listed in the links are finish sanders. For a deck you will need to plunk down the extra bucks to go with a sander that will last like the Porter-Cable 734.
The Porter-Cable 5 or 6 inch is an aggressive sander and will hold up to heavy use. There are others out there and I can't say that there aren't aggressive sanders in the price range you wish, I just don't know of any.
Another sander I have that is more aggressive than a finish sander is the Bosch 3727 RO sander. It is a good sander but it isn't cheap.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-24-2011, 08:49 AM   #3
hyunelan2's Avatar
Rewards Points: 690
Looking at the PC 734# models,
6" http://www.amazon.com/dp/B002EQ96MG/...SIN=B002EQ96MG
5" http://www.amazon.com/Porter-Cable-7.../dp/B002EQ96O4
Their price is right about equal. Their specs are equal. It's just a difference between a 5" or a 6" head. On the deck, the 6" would get things done faster, but I'm afraid that after that it might be too large for some applications? (I don't know what specifically). Is it possible to buy the other head and use it as either 5 or 6?
Old 03-24-2011, 12:52 PM   #4
uva uvam vivendo variafit
WirelessG's Avatar
Rewards Points: 698
I have the DeWalt that you cited and it's a pretty good sander. I don't think the variable speed feature is of importance on the RO sander as it is not meant to remove material like a belt sander. The 3.0 amp motor is stout enough for rough removal on a coarse grit, but also does a nice job on med-fine grits. I don't think I would go for a weaker motor.
You may need to reevaluate what you want the sander for. The sander that jiju is suggesting are a little bit on the more powerful end that what you may want once you finish the deck work. What are you trying to do to your deck? Remove mold and stains? If you are only looking to clean it up, try a pressure washer or Clorox Pro Results.
WirelessG is offline   Reply With Quote
Old 03-24-2011, 01:41 PM   #5
hyunelan2's Avatar
Rewards Points: 690
Thread crossover: Deck Power Washed...now many days of rain before stain!
I am not the OP in that thread, but have relevant discussion. I need to clean/p-wash, then sand my deck so the stain will take to it.
I was wondering if the 3.0a motor of that DeWalt would be strong enough for the job. Post-deck, I would use it for some DIY woodworking projects, cabinet building, refinishing an old dresser, etc. If I went the route of the PC, I could also use that for car polish/detail work, and not have to borrow a polisher when I need to get rid of swirls. However, at double the cost, the DeWalt is looking more attractive at the moment.
Old 03-24-2011, 03:20 PM   #6
WirelessG's Avatar
Rewards Points: 698
In that case, I would get the bigger sander for the deck and the DeWalt for other DIY sanding. On your deck boards, you might as well rent a floor sander. It's gonna be a big job.
Old 03-26-2011, 06:24 AM   #7
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
...I was wondering if the 3.0a motor of that DeWalt would be strong enough......
I would not consider any model less than a 4 amp tool for any serious sanding.
I have a DeWalt 4.3A for > ten years and it is still going strong.
It will drive six" 36 Grit Discs for heavy duty sanding, though I would not attempt to use it on deck floor boards.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-27-2011, 08:05 AM   #8
Rewards Points: 5,336
  • 2.0a vs. 3.0a
Thanks!
You either have a very small deck or the patients of Job. These sanders will take forever to get the job done.
Even the Porter Cable unit will take awhile to sand a deck. I have the unit and use it more then either the belt or palm sander.
What sort of finish are you removing?
Ron
Old 03-27-2011, 10:26 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 290
If you go with the Porter-Cable, I would go with the 5 inch as the disks are easier to find. Lowe's has that sander for $120 right now.
Jim
Old 03-27-2011, 11:54 AM   #10
Tool Geek
PaliBob's Avatar
$120 for the Porter Cable (4.5 Amps)
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-27-2011, 10:19 PM   #11
Tool Geek
PaliBob's Avatar
A Factory reconditioned 4.5 Amp Porter Cable can be had for< $100
$6.99 Flat Rate Shipping
1 Year Warranty
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
hyunelan2 (03-28-2011)
Old 03-28-2011, 07:49 AM   #12
hyunelan2's Avatar
Rewards Points: 690
Good work on that link. I may have to order that one today!
EDIT: ordered this morning. Thanks for the link. I found it elsewhere for about $20 more new, but figured a CPO from PC/DELTA was just as good as new. I've purchased CPO tools before and was never disappointed.
random orbit floor sander carpdad Flooring 2 10-12-2010 01:47 PM
Random Orbit Sander TrafficCopSmith Tools 1 01-14-2010 08:57 PM
Ridgid Random Orbit Sander jamiedolan Tools 2 03-17-2009 02:23 AM
Orbital Sander - Variable Speed handy man88 Tools 6 11-27-2007 08:33 PM
Drum Sander -vs- Disk Sander BlueGuy Flooring 7 08-20-2006 09:44 PM
