Ramset Cobra Jammed - Tools - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 10:31 AM   #1
Ramset Cobra Jammed
I have a jammed Ramset Cobra with a broken piston which has been removed from the gun and several live loads still inside.
I have disassembled the handle however the front barrel pawl only pivots slightly but will not release.
I need some pointers on dismantling safely and overhauling with a new piston. Is there any other damage I should be looking for...and what is the safest way to remove the charge caps.
BTW I didn't damage it, I bought it this way for $10 and its time to use it soon.
Chemist1961 is offline   Reply With Quote
Old 10-19-2010, 10:44 AM   #2
Rewards Points: 558
If you have any broken or damaged parts I would take it to a ramset/redhead dealer for service as they are trained to fix and or repair there tools. But if you want to try it yourself then check this out: http://www.itwconstruction.ca/files/manuals/Cobra_Manual.pdf
epson is offline   Reply With Quote
Old 10-19-2010, 12:52 PM   #3
Thanks I have that info sheet and parts available for $42 for the piston, but the repair depot siad it would be at least $90 for the part and I could buy a new gun for $150 on sale at Home Depot...Not sure what HD that is.
Old 10-20-2010, 09:17 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I am confused, can't you just pull the strip out? It's been a while since I've had one of these apart, but it's pretty easy. There is a big clip you need to pop off, then pull out the piece the clip was holding in, and the whole barrel assemble will come right out. I used to be able to change pistons on these in minutes.
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 10-20-2010, 09:24 AM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
I may have a new piston that will fit this gun. I know it fits the Hilti version of this gun. PM me with your address and I'll ship it to you
Looking to upgrade my Cobra power auger Jeekinz Plumbing 1 04-26-2011 05:23 PM
Cobra Roof Vent Coral Kemp Roofing/Siding 3 09-02-2010 12:00 AM
Low-Slope Ventilation - Cobra Fascia Vent and Cor-a-Vent Roof-2-Wall vent atulc Roofing/Siding 7 08-22-2008 11:40 PM
Ramset with hilti powder charges JFD140 Tools 3 08-06-2007 05:02 PM
kenmore icemaker/crusher getting jammed markm Appliances 1 06-03-2007 11:25 AM
