Ramset Alternative? - Tools - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 11:29 AM   #1
Ramset alternative?
Hey guys,
I've been using a Ramset rs22 for framing basements when I need the bottom plate to tie into the concrete floor. I use the yellow shot with 3" nails and I find that more often than not the nail does not bite very well into the concrete because it doesn't have enough power to sink the nail much more than 1/2". I am thinking about moving up to a .25cal ramset but the cheapest one I can find is $320. Does anyone know of a cheaper ramset than will have no problems sinking 3" nail through a 2x4 and into concrete?
thanks.
McCool is offline   Reply With Quote
Old 01-31-2011, 10:05 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
look for a .27 cal gun. most of the .25 cal guns are specialized for guys doing metal drywall studs and will be more expensive and only shoot up to 1-1/2"
The ramset Cobra is cheap
http://www.amazon.com/Ramset-Powder-...6533075&sr=8-2
or look on craigslist or ebay for a used hilti
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 02-01-2011, 09:17 AM   #3
Rewards Points: 268
have you considered using meal track for the top and bottom plates? They are easier to fasten to concrete, you set the studs {metal OR wood} in them and screw in place. I do some of this work alone and it saves me some time using the metal track.
packer_rich is offline   Reply With Quote
Old 02-02-2011, 05:57 PM   #4
Tapcons work really well too. I use both-- My walls never move with either but the ramset I have is faster. The only time I have a hard time is on older homes( 20 years or older) concrete is really hard lol. If you want to save the money cut nails work really well too.
proremodel is offline   Reply With Quote
Old 02-03-2011, 12:31 AM   #5
Rewards Points: 502
Are you a contractor or is this a 1 time thing for your own basement?
I prefer an expanding concrete anchor, or concrete screws but they take much more time to install (anchors more than screws) Either takes some concrete drilling and tightening up for an install, so now tool investment for the most part.
forresth is offline   Reply With Quote
Old 02-04-2011, 12:45 AM   #6
We're using Titen HD's now, slower but man they hold! http://www.simpsonanchors.com/catalo...ical/titen-hd/
Kingstud is offline   Reply With Quote
Old 02-04-2011, 04:10 PM   #7
Drywall contractor
Rewards Points: 1,070
As long as the plate doesn't move once you shoot it, 1/2" penetration is enough. I've got a .25 cal. Hilti, but I use the Remington .22 because the shot/pins are cheaper. If you're worried, use adhesive under your bottom plate.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-02-2011, 02:21 PM   #8
I am looking at the cobra III .27 cal but it can only use 2 1/2" shot and I need 3" for subflooring basements.
I think I am going to move over to tapcons and hammer them in with an impact drill.
Old 03-02-2011, 05:04 PM   #9
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
with Powder Actuated Tools, most manufacturers recomend not trying to exceed a 1-1/2" embedment into normal weight concrete. the tools aren't designed to drive them any deeper, and the risk of fish hooking increases. the other "rule of thumb" is your base material should be at least 3x your embedment depth
Alternative ceiling material wkharden Carpentry 6 07-01-2011 06:54 PM
Does anybody use/suggest Ramset pins for attaching base plate to cement? jobblyman Building & Construction 23 10-29-2010 11:39 PM
Is it possible to use grout as an alternative to Levelquick? LoneStarGuitar Building & Construction 4 08-31-2010 09:13 AM
Ramset over drive JFD140 Tools 2 08-08-2007 06:22 PM
Ramset with hilti powder charges JFD140 Tools 3 08-06-2007 04:02 PM
