Radial Arm Saw Stopped Working - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 02:55 PM   #16
Rewards Points: 150
Failing that, can I bypass the switch or relocate it somehow? The second Sears Radial arm saw I bought did not have a reset switch on it (it is older).
sheslostcontrol is offline   Reply With Quote
Old 07-19-2013, 12:17 PM   #17
Stopped radial arm saw
I'm glad they kept this thread open since I just encountered the same problem in July 2013. I let the motor cool down then pressed the reset button with no results. After doing this a number of times I finally went to this chat room and found the answer right there. I went back out, pressed and held the reset button quite hard until I heard a second click and the saw came right back on. Thanks (you think as a Sears retired Craftsman power tool buyer I would have figured that out).
Bob
Scotsman88 is offline   Reply With Quote
The Following User Says Thank You to Scotsman88 For This Useful Post:
PaliBob (07-20-2013)
Old 07-19-2013, 12:25 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Bob
Glad you found the answer here on one of our older threads.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 08-27-2015, 05:52 PM   #19
This thread has proven to be useful yet again. Two months ago I bogged my saw down doing something I shouldn't have. I haven't needed it since because all of my projects have been small. I have a bigger project coming up where I'm building my little girl practically a complete play kitchen with sink, stove, fridge, and pantry. I will be needing this saw. Read the thread - pressed hard until the second click - saw is up and running again!! Thanks guys!
MikeyA is offline   Reply With Quote
The Following User Says Thank You to MikeyA For This Useful Post:
oh'mike (08-27-2015)
Old 08-27-2015, 06:22 PM   #20
DIY staff
Rewards Points: 7,174
I enjoy seeing older threads helping folks---glad this worked for you--
Old 08-27-2015, 08:31 PM   #21
GrayHair's Avatar
Rewards Points: 1,002
This is another reason I like to see the resolution to problems.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
The Following User Says Thank You to GrayHair For This Useful Post:
Old 09-03-2015, 01:28 AM   #22
Rewards Points: 318
I would like to take this thread into a different direction. I have heard nothing but bad things about RAS. I was thinking of purchasing one last year, and was told by many that its a dangerous tool. These days with sliding miter saws and the like, I dont know why people would need one.
drew53813 is offline   Reply With Quote
Old 09-03-2015, 11:17 AM   #23
Rewards Points: 5,982
They will accept Dado blades which makes them handy for cutting rabbits and dados.
Entering your general location can help with answering a lot of times
Old 09-03-2015, 02:53 PM   #24
Rewards Points: 318
A table saw does as well. No moving blade on those
Old 09-03-2015, 03:58 PM   #25
Mad Scientist
The other name for 'em is "Radical Harm Saw"
It's a little exciting when you get your setup a little wrong and it decides to dig in, kick, self-feed, and generally just come at you with malicious intent. I've never seen it as any more or less dangerous than a table saw, though.
McSteve is offline   Reply With Quote
Heat Pump Fan Has Stopped Working TurboSteve HVAC 2 12-15-2010 12:40 PM
Ice Maker stopped working Whirlpool ED5FHEXNQ00 Hotlatte Appliances 1 05-14-2009 03:15 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 09:47 PM
Multiple 4 way switches stopped working Keniki Electrical 3 07-30-2008 01:34 PM
Rheem furnace stopped working kgsolomon1 HVAC 1 02-09-2008 06:51 PM
