Quick Question About Drills... - Tools - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 04:16 AM   #16
Bill Kearney
Rewards Points: 1,174
With cordless you really want to stick to a single battery type. This so you can swap them between the devices. Note, I wrote battery type, not brand as some brands have different models of batteries, usually based on voltage. As in, DeWalt 18v vs 20v. Other brands do this also, usually because the higher voltages provide more power for heavier-duty stuff.
1/2" is great if you only have one, but they are heavier. This gets tiring after a while if you're doing a lot of work. But for typical DIY it'd be fine.
Also note if you get into any close-quarters work (like between joists) it helps to have as short a distance on the unit as possible. Or have a right-angle drill instead. Otherwise you can't quite get in there with the drill AND the drill bit. They do sell shorter bits but then you can't drill through as much material. A right-angle drill lets you use normal length bits.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
jeremy511 (04-17-2013)
Quick question with cement board and underlayment supastar1568 Flooring 7 01-05-2012 05:03 AM
Quick Wire Size Question leeave96 Electrical 5 08-22-2011 05:33 PM
Quick outlet question RodBarney Electrical 5 08-20-2011 12:06 AM
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 12:18 AM
Quick Bathroom Plug and switch Question mclemenc Electrical 5 01-30-2011 10:02 PM
