PT Deck Repair - How Many Saws? - Tools - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 06-27-2016, 06:13 PM   #1
Rewards Points: 12
Hello,
I am going to need to buy a few saws for a deck repair project and welcome input regarding how many I need to buy.
The repair calls for cutting two 4x4 railing posts to size along with four 2x4 railing tops/bottoms (the deck balusters are pre-cut).
Additionally, I may need to remove and replace portions of a few deck boards that have split. The replaced sections will need to be notched to fit around the new 4x4's. I imagine this stuff is all circular saw, correct?
Lastly, the old 4x4 rail posts were notched and I would like to install the new ones "whole". In order to do that it looks like I need to trim one of the side joists a bit (and then block?). For this do I need a reciprocating saw ANG a jig or can I get away with just one.
Thanks for the feedback!
cs006b is offline   Reply With Quote
Old 06-27-2016, 07:46 PM   #2
Usually Confused
lenaitch's Avatar
Rewards Points: 1,992
Re: PT Deck Repair - How Many Saws?
You should be able to do all that with a standard 7 1/4" circular saw plus a hand saw to finish off the notch cuts. The deck boards can be mostly cut out with a plunge cut on the circular saw and a hand saw to finish the cut.
lenaitch is offline   Reply With Quote
Old 06-28-2016, 06:50 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
If this is the only project you have planned, I would do it with what you have. If you have other projects lined up... miter saw, table saw, jig saw, sawzall, and a circular saw will make the job easier.
SPS-1 likes this.
Clutchcargo is offline   Reply With Quote
Old 06-30-2016, 02:40 PM   #4
Rewards Points: 848
Easy justification to buy a circular saw if you don't have one already.
stick\shift is offline   Reply With Quote
Old 06-30-2016, 05:26 PM   #5
DIY staff
Rewards Points: 7,174
Notching or modifying joists is seldom a good idea----better to notch the post than to weaken the structure--more details ,please.
Old 06-30-2016, 08:12 PM   #6
Rewards Points: 1,453
I think circular saws are way overrated. More of a construction tool. Good if you want to make a bunch of straight cuts in plywood, like a new floor or roof. Not really the best tool for a typical homeowner to make small repairs.
A good jigsaw is much safer and easier to control and there are lots of different blades available for all kinds of materials and the blades are much cheaper and easier to change. Fast cuts. Clean cuts. Plunge cuts. Curved cuts. Straight cuts.
A jigsaw will do everything. But you have to get a pretty decent one. There are a bunch of really cheap, underpowered jigsaws that give the whole category a bad name.
This one should be good for you:
https://www.amazon.com/dp/B0006FIOE8..._t2_B0007XXHHI
mathmonger is offline   Reply With Quote
Old 07-01-2016, 02:09 PM   #7
Rewards Points: 848
That does look like a good jigsaw and I do own one as well but I think of it as a finishing/light duty saw, whereas the circular saw gets used for cuts through bigger pieces of wood. Just my 2.
Old 07-01-2016, 06:07 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,250
any deck builder will pretty much rely on a circular saw. maybe just maybe a recip saw but its not really necessary,, and ajig saw for cutting notches in decking itself.. hate to say it but the second last poster doesnt really know what hes talking about when it comes to a circular saw.. they are hte workhorse tool of the jobsite
woodworkbykirk is offline   Reply With Quote
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
kwikfishron (07-04-2016), oh'mike (07-04-2016)
Old 07-04-2016, 03:59 PM   #9
I just listed a bunch of reasons why a jig saw is better. And all you can say is "everybody uses circular saws". That's my whole point. They are overrated. Some people just can't see the forest through the trees.
I don't even keep a circular saw on my truck anymore. Once in awhile, I will use one for cutting concrete.
Old 07-04-2016, 06:08 PM   #10
interesint since im in high end renovations and custom home builds... i do every stage of constrution and a circualr saw comes out daily,, my jigsaw only comes out for notching deckboards for posts and for scribes when doing trim and cabinet work... .. if your ripping boards or crosscutting ill take a circular saw any day over a jigsaw no matter how good the jigsaw because the blade will still wander
asevereid likes this.
Old 07-05-2016, 11:28 PM   #11
Yup. That's what I said. It is a construction tool. I'ts a productivity tool. I'm not trying to convince anybody that they should be building homes with just a jigsaw.
The OP has to cut 2x4's and 4x4's, cut out sections of old decking, and notch the new decking.
For cutting 2x4's, either saw would work easily.
For cutting 4x4's, he could cut it and flip it and cut it again with a circular saw. Or just cut it in one pass with the jigsaw.
For cutting out old sections of decking, he might be able to plunge cut the middle with the circular saw, but it won't get the edges due to the radius of the blade. The jigsaw goes straight up and down, so he can stop exactly where the cut has to stop.
For notching out the new wood, again, the circular saw could only do half the job. The jigsaw makes a nice square corner.
The jigsaw is less likely to kick and hurt somebody.
A jigsaw with decent power, orbital action, and an aggressive blade really can cut pretty quick.
The jigsaw is more versatile for future jobs.
The jigsaw blades are smaller, cheaper and much easier to change.
The only reason this guy needs a circular saw is if he wants to pretend he's a construction worker. If that is the case, I recommend a tool belt and a hard hat - and a jigsaw.
Old 07-06-2016, 02:16 PM   #12
a jig saw will not make a clean cut in a 4x4.. trust me bud ive made just about every type of cut possible with every type of saw there is... its not about using any saw for the job its about using the right tool for the job.. . ]
The Following User Says Thank You to woodworkbykirk For This Useful Post:
kwikfishron (07-06-2016)
Old 07-06-2016, 03:58 PM   #13
Oso954's Avatar
Rewards Points: 1,342
Especially when used by a person asking what saw to use.
For the few cuts he listed, a good handsaw would work.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
woodworkbykirk (07-06-2016)
Old 07-06-2016, 07:28 PM   #14
Yeah, that's basically true for the $80 jigsaw. But have you ever done this cut:
I never tried one. Looks pretty cool, though.
Old 07-06-2016, 11:20 PM   #15
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
I used to have the corded model of that jigsaw. I never cut a 12x12 with it but it cut a 4x4 great.
I hate signatures.
Mort is online now   Reply With Quote
Sagging Deck Repair Options daprofsr47 Building & Construction 5 03-24-2016 11:30 AM
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Deck Repair Help nevon Building & Construction 5 05-18-2011 10:11 PM
Bad deck construction needs repair Photohv Building & Construction 6 07-15-2010 09:41 AM
