Pressure Washer Problem - Tools - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 12:23 PM   #1
Rewards Points: 31
Pressure washer problem
I have a troy-bilt 2550 psi gas pressure washer with a 6.75 briggs. Model 020337
I just pulled it out this week to use it, haven't touched it since last year. It started fine but i have very little water pressure and the engine sounds like it's in a real bind. It will push water out of the detergent inlet but not much out of the wand.
If i unhook the wand the engine runs fine and it really pushing the water out of the wand outlet, nothing out of the detergent inlet without the wand.
I took the pump off and a part as far as i could get it and soaked it in clr and i still have the same problem.
I'm thinking this is the unloader, any ideas?
webweever is offline   Reply With Quote
Old 10-16-2012, 01:14 PM   #2
Rewards Points: 79
How does it run with the wand attached but not trying to force any water through? I wonder if it's an issue with something clogged in the wand? Sounds like the pump is running well if you get a lot of water out of the port with the engine running and the wand not connected so I'd think a wand issue.
itguy08 is offline   Reply With Quote
Old 10-19-2012, 01:39 AM   #3
Oso954's Avatar
Rewards Points: 1,634
clean the water inlet screen.
Oso954 is online now   Reply With Quote
Old 10-19-2012, 04:33 AM   #4
Rewards Points: 27
I think your thoughts are correct. Don't run it with a stuck unloader. That can do serious damage to the pump. Remove the unloader and either disassemble and cleaned it or replace it.
Idmason60 is offline   Reply With Quote
Old 10-19-2012, 12:22 PM   #5
Oso954's Avatar
Small amounts of sediment on the water inlet screen restrict the flow.
The flow restriction causes the pump to cavitate.
Flow thru the wand drops as well as pressure.
Try removing the inlet screen, backwash it, and reinstall.
Then try starting it one more time.
I believe I see more than enough sediment in the screen to be causing your problem.
Old 10-21-2012, 05:21 PM   #6
jschaben
Rewards Points: 502
I do believe the problem, at least most of it is in the wand. Unloader sounds like it's working. It's normal for it to load the motor down when the output is restricted. I've seen those wands almost completely rusted closed. I've changed mine to stainless steel and blow all the water out of the hose and wand after every use.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-21-2012, 09:23 PM   #7
Rewards Points: 31
Thanks for the advise everyone. Unfortunately i probably won't get back to getting this thing running till next summer, deploying soon.
Old 10-22-2012, 07:17 AM   #8
Rewards Points: 27
I am proud and thankful of your service to our country. Thank you so much for that. Also for families dedication to you while you are away. Take care of yourself and your buddies while your there. Be safe. We will be here when you return. Thanks again.
Larry
S. Florida
Old 10-22-2012, 09:59 AM   #9
Rewards Points: 31
Thanks Larry, we appreciate your support.
Honda pressure washer not making pressure brandon1023 Tools 1 07-23-2012 05:29 AM
Pressure washer blew the garden hose tucker0104 Tools 6 05-29-2012 06:51 PM
Campbell Hausfeld 2030 Pressure Washer Problem 68rs327 Tools 3 11-09-2011 10:04 AM
Hot water pressure problem (unusual situation) tanna Plumbing 2 09-03-2011 08:17 AM
Home water pressure problem ATLdrew Plumbing 13 04-24-2009 11:17 AM
