Pressure Washer Manifold Replace - Tools - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 11:25 AM   #1
First you should know that I am a total novice.
I have a Troy Built Pressure Washer Model 020208.
The threads on the manifold are stripped so I have ordered a new one.
While I wait on the shipment of the new manifold, I removed the old one and noticed that the check valves were covered with a white build up (lime or calcium?) I removed the valves and cleaned them with vinegar and they seem to be working properly. My question is, should I be doing any other maintainence while I have the manifold off? Should I use any type of lube or greese when reinserting the valves and manifold? Im sure this is rutine stuff for you guys but I am clueless.
Thanks for your help.
DIY JIM is offline   Reply With Quote
Old 10-12-2009, 02:54 PM   #2
Household Handyman
Rewards Points: 1,408
The check valves should be made of Stainless Steel and will need no lubrication. Be sure to put the check valves back in as they were removed, or your unit will not work. IF this is a gas powered unit, it would be a good time to change the oil, clean the air filter, change the spark plug, and generally clean the motor unit. You may want to change the oil in the pump unit as well, it wouldn't hurt it. Be sure to follow the manufacturer's instructions for oil in this unit. IF it is an electric unit, check the power cord and it's connection at the motor. Good Luck, David
Old 10-12-2009, 03:41 PM   #3
Thanks Dave!
Old 10-13-2009, 08:50 PM   #4
manifold
You may not need to replace the manifold just the " Inlet pipe".
find parts list by Googleing "Trot Bilt parts replacement"
terborkanxarb is offline   Reply With Quote
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 06:29 PM
Pressure washer advice mntentman Tools 1 09-03-2008 09:36 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Replace Water Pressure Regulator tparker Plumbing 1 12-07-2007 07:47 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 02:43 PM
