Pressure Washer On Lawnmower - Tools - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 10:58 AM   #1
pressure washer on lawnmower
Is it generally ok to use a pressure washer in light spray mode to clean the bottom of my lawnmower? Alot of grass, mulch, dirt, etc.....is caked on there and it's tough to get off.
dinosaur1 is offline   Reply With Quote
Old 10-08-2011, 01:08 PM   #2
A Little Of Everything
Rewards Points: 1,356
Are you talking about the under-side of your deck? If so, the answer is absolutely YES. Just be aware of the fact that, when you tip it up on its side, you're probably going to be running gas and/or oil out onto the ground.
DrHicks is offline   Reply With Quote
Old 10-08-2011, 03:54 PM   #3
Just make sure you tip it w/ the air cleaner up not down or oil will saturate air filter and carb!
toolaholic is offline   Reply With Quote
Old 10-08-2011, 08:51 PM   #4
Worked out wonderfully. How often should I do this? Looks great! Mad I didn't do it more this past summer.
Old 10-08-2011, 08:55 PM   #5
KemoSabe
loneframer's Avatar
Now that it's clean, spray the underside of the deck with some non-stick cooking spray. Should clean up with a garden hose next time.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 10-08-2011, 08:56 PM   #6
I normally use silicone spray.
Old 10-09-2011, 09:02 AM   #7
That works well! Good choice
Old 10-09-2011, 09:48 PM   #8
Thanks!
Has anyone built a hot water pressure washer ? Sin-city-custom General DIY Discussions 11 09-10-2015 11:57 AM
Looking for a motor capactitor for pressure washer andy1033 Electrical 0 10-07-2010 08:05 AM
pressure washer on well water Hardly Handy Plumbing 3 09-06-2010 09:16 PM
Pressure Washer Manifold Replace DIY JIM Tools 3 10-13-2009 08:50 PM
What to look for in a Pressure Washer ? Scott_K Tools 5 07-03-2005 02:43 PM
