Power Tool Recommendations - Tools - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 12:35 PM   #1
Power tool recommendations
With black friday coming up, tools are on sale from companies like; Ryobi, Rigid, Dewalt, Makita, Milwaukee
Looking at getting at least a drill if not one of the combo kits, which manufacuter would you recommend?
toastandjam is offline   Reply With Quote
Old 11-17-2012, 12:47 PM   #2
Rewards Points: 13,446
What do you plan on using them for? Around the house or real work?
Old 11-17-2012, 12:55 PM   #3
Just around the house.
Currently have a corded drill and an old corded 7" circular saw with a repaired cord that I got for free.
Old 11-17-2012, 01:08 PM   #4
I'd look for a Ryobi set that includes an impact hammer drill. Also called a drill driver.
Low up front cost and the batterys cost about 1/2 of what anyone else charges.
Are the other brands except Dewalt better, yes, worth the extra cost for home owner use, not likly.
May want to check out CPO tools for some deals on factory reconditioned tools.
Same warrenty and much lower prices.
Old 11-17-2012, 04:39 PM   #5
Davejss's Avatar
Rewards Points: 740
I have a Makita combo set that came with an impact driver and a 1\2" hammer drill. They are 18 volt Lithium Ion batteries and they are amazing. They hold a charge forver. I'm a remodeling contractor and my tools take a beating. These have held up very well for the three or four years that I've had them.
Ryobi has come along way over the years as well. They are probably a bit less exspensive than Makita and others.
Which ever brand you go with I would deffinately recommend the LiOn batteries.
Davejss is offline   Reply With Quote
Old 11-17-2012, 05:11 PM   #6
Rewards Points: 5,974
I would second the royobi For what you want it sounds like a good fit. But I would look at the kit rather than individual tools simply because it cheaper than 1 tool at a time. And eventually, unless you are the world luckiest home owner you will need the rest of the tools.
Old 11-17-2012, 05:16 PM   #7
A few of the Ryobi tools I have owned in the past and found then useless are the jig saw, battery operated ciruler saw and chain saw.
Old 11-17-2012, 08:18 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,446
I have a crap load of the Ryobi tools.....All perform well...
Except.....
Circular saw....great for cutting one sheet of plywood...easy to handle...but that one sheet will drain a fully charged NiCad battery
Hand vac is worthless
All the other tools have helped me build my garage and house....
What ever you choose....stick with a voltage and brand. That way all your batteries and chargers work for all the tools.
ddawg16 is online now   Reply With Quote
Old 11-17-2012, 08:29 PM   #9
I forgot about that one. All those small vac are less then useless.
One more I forgot is there 6 battery charger.
I thought this would be great for at the end of the day to put all 6 of my batterys in and have them ready in the morning.
It only charges one battery at a time. The next day only only 1/2 were charged.
PaliBob (11-18-2012)
Old 11-18-2012, 11:44 AM   #10
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I've got the Craftsman 19.2v set. There batteries have a somewhat tarnished reputation, but I've found that if you don't leave them on the charger for way too long, they've worked great for me. And Lord knows Sears could use the money.
Mort is online now   Reply With Quote
Old 11-18-2012, 12:37 PM   #11
i'd wait til the after christmas clearance sales
Old 11-18-2012, 12:47 PM   #12
Old 11-18-2012, 01:02 PM   #13
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,108
i just picked up the makita lxt drill and impact set with fatpack batteries.. for the same price i could have gotten the brushless version with a 99pc bit set.. however only the slim pack batteries
woodworkbykirk is online now   Reply With Quote
Old 11-18-2012, 09:35 PM   #14
Good choice! How often do brushes really need replaced and how much more power does brushless generate. I'd go for the bigger batteries too!
toolaholic is offline   Reply With Quote
Old 11-19-2012, 12:09 PM   #15
+1 for the ryobi (drivers at least). I've been using them every weekend for the last 4 months and they've been great. Really like the impact driver and it's quite affordable. I'd splurge on the Bit set though... i got the ryobi 90 piece and some of the bits are of dubious quality/strength.
fourx is offline   Reply With Quote
Power tool invention TimsTools Tools 13 05-27-2011 09:37 PM
Power tool Junkie Question UpComingBuilder Tools 3 10-05-2009 09:24 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
DIY for home improvememt with power tool kakakawai General DIY Discussions 3 11-12-2005 08:47 AM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
