Power Tool Batteries And Maintenance - Tools - DIY Chatroom Home Improvement Forum
Old 03-03-2012, 05:20 PM   #1
Power tool batteries and maintenance
Anyone else drain their niCD batteries completely before recharging them?
While liIon have no memory effect the suck when they're old and just die. I have 6 niCD batteries and they're beasts. I've had them several years and always run them in my drill with the trigger taped on till they die completely. It's a bit extreme but that's why I don't need to replace my $80 a piece batteries.
Any suggestions on a better way to discharge these batteries? They're ridgid 18volts
Al
Albe is offline   Reply With Quote
Old 03-03-2012, 05:24 PM   #2
Rewards Points: 13,296
Edit edit
Old 03-03-2012, 05:30 PM   #3
Al
A 120v, 60W incand. bulb will discharge this battery at about a 1A rate, a 100w bulb at about 2A and 30' of #30 AWG wire wrap wire will do about 6A (and get pretty hot).
Old 03-03-2012, 08:02 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
draining a nicad battery till its totally dead is a bad thing, once you notice a power drop in the tool it should go on the charger. i learned this years ago both from the reps with the tool companies and also from a few trade publications
lith ions can be charged at any time as they have a chip inside them which eliminates "memory"
woodworkbykirk is offline   Reply With Quote
Old 03-04-2012, 04:44 PM   #5
I've heard 80% depth of discharge (DOD) is OK.
High-level maintenance schedules? NothingsLevel General DIY Discussions 1 09-05-2006 12:25 AM
