-   Tools (http://www.diychatroom.com/f29/)
-   -   Power tool batteries and maintenance (http://www.diychatroom.com/f29/power-tool-batteries-maintenance-135828/)
Albe 03-03-2012 05:20 PM
Anyone else drain their niCD batteries completely before recharging them?
While liIon have no memory effect the suck when they're old and just die. I have 6 niCD batteries and they're beasts. I've had them several years and always run them in my drill with the trigger taped on till they die completely. It's a bit extreme but that's why I don't need to replace my $80 a piece batteries.
Any suggestions on a better way to discharge these batteries? They're ridgid 18volts
Al
joecaption 03-03-2012 05:24 PM
Edit edit
Yoyizit 03-03-2012 05:30 PM
Al
A 120v, 60W incand. bulb will discharge this battery at about a 1A rate, a 100w bulb at about 2A and 30' of #30 AWG wire wrap wire will do about 6A (and get pretty hot).
woodworkbykirk 03-03-2012 08:02 PM
draining a nicad battery till its totally dead is a bad thing, once you notice a power drop in the tool it should go on the charger. i learned this years ago both from the reps with the tool companies and also from a few trade publications
lith ions can be charged at any time as they have a chip inside them which eliminates "memory"
Yoyizit 03-04-2012 04:44 PM
I've heard 80% depth of discharge (DOD) is OK.
