Power Mixer For Thinset - Tools - DIY Chatroom Home Improvement Forum
Old 03-19-2013, 06:50 PM   #1
Lightbulb
power mixer for thinset
I need a power mixer for thinset. If i buy a 1/2" drill, can it also be used for 3/8 drill bits? I won't be laying floor tiles much so i also want a regular style drill. Thank you
for example http://www.sears.com/shc/s/p_10153_1...=31-99064534-2
DiyCR fan is offline   Reply With Quote
Old 03-19-2013, 07:09 PM   #2
firehawkmph's Avatar
Rewards Points: 1,824
Diyer,
you'll burn that drill up in short order if you're mixing thinset in a 5 gallon bucket. You need a 1/2" low rpm torque type drill like this:
http://www.amazon.com/Milwaukee-1660.../dp/B0000223HQ
If you're not using it all the time, you can find an off brand for a lot less money. I've had one of these milwaukees for about 10 years now. Works great. All power tools come from the factory with only so much smoke loaded in. In the case of the litte drill, if you let all the smoke out, it won't run anymore.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
DiyCR fan (03-19-2013)
Old 03-19-2013, 07:30 PM   #3
Lightbulb
Ty all... firehawkmph unfortunately that's too expensive for me. Would this Milwaukee do? http://www.homedepot.com/p/t/1000268...7#.UUjuVlfO3kA
Old 03-19-2013, 07:44 PM   #4
i see the milwaukee right angle drills all the time on CL for anywhere from 75-125 dollars. they are low speed with a lot of torque.
The Following User Says Thank You to DannyT For This Useful Post:
Old 03-19-2013, 09:45 PM   #5
Diy,
I agree with what Danny said. Look for a good used one. The milwaukee you linked doesn't have the low end grunt needed. You don't want a lot of rpms when mixing thinset, drywall mud, etc. You'll just end up with a big mess.
Mike Hawkins
Old 03-19-2013, 10:05 PM   #6
Thumbs up
HD was out of stock on the Milwaukee (grrr), so I bought this Hitachi D13VF 9 Amp 1/2-Inch Drill for $90 http://www.amazon.com/Hitachi-D13VF-...srch_res_rtr_1 great price, great reviews & above all like you guys mentioned low rpm's/high torque ... can't wait to lay down the smacketh on these tiles... normally don't but i needed it so i ordered 2-day shipping. Thanks a bunch guys!
Old 03-19-2013, 10:50 PM   #7
Let us know how that works once you get it.
Mike Hawkins
Old 03-19-2013, 11:25 PM   #8
Thumbs up
Mike Hawkins
i'm an amateur but i'll do my best
Old 03-20-2013, 11:19 PM   #9
Lightbulb
I was just watching a video about power mixers. The guy mentioned get one that has a "reverse switch" to help you clean the mixing paddle. The one i bought has a reverse switch. But how does it help clean the mixing paddle? Please elaborate. Thank you
Old 03-21-2013, 02:56 AM   #10
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by DiyCR fan View Post
..... But how does it help clean the mixing paddle?......
Here is my rig with the old original case and the new case. I have never heard of that that reverse to clean thing.
power mixer for thinset-flambeau-top.jpg   power mixer for thinset-mudmixer-2.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
DiyCR fan (03-21-2013)
Old 03-21-2013, 08:00 AM   #11
Rewards Points: 5,974
I also have an old craftsman 1/2" that I have had for probably 20 years has the D handle all I use it for is mixing thin set, concrete, grout, drywall mud, and the like. In fact I think it's the only craftsman tool I have, except hand tools.
Old 03-22-2013, 03:31 PM   #12
Reverse doesn't really clean it. Get a scrub brush and clean it while its still wet. Only takes a sec. If you let it set up, then you'll have to chip it off.
Mike Hawkins
DiyCR fan (03-22-2013)
Old 03-22-2013, 06:53 PM   #13
Thumbs up
Mike Hawkins
I see. Yup, that's what i did; i just dipped it in a bucket of water & scrubbed. Very easy & very grateful it was easy because i am not a pro
As for the Hitachi power drill, it definitely saves me lots of energy. I'm able to put down more tiles at once... 9 amps is powerful enough to mix the FlexBond Crack Prevention Mortar. I did smell a slight smoking of the motor, but that happened only one time & my fault because the thinset was too thick. A bit heavy but not a bother. I love that machine
Old 03-23-2013, 01:21 AM   #14
Glad it working out. Your hitachi is 0-850. If you got a 0-500/550 pistol grip or a single speed 450rpm spade hsndle it would even turn the thickest thinset.
toolaholic is offline   Reply With Quote
The Following User Says Thank You to toolaholic For This Useful Post:
DiyCR fan (03-23-2013)
Old 03-27-2013, 08:25 PM   #15
Bigplanz's Avatar
Rewards Points: 952
This is cheap and well regarded for mixing thinset.
http://www.harborfreight.com/1-2-hal...ill-93632.html
Bigplanz is offline   Reply With Quote
The Following User Says Thank You to Bigplanz For This Useful Post:
DiyCR fan (03-28-2013)
TV power bridge into existing outlet and protected by an external surge protector andytran73 Electrical 4 12-14-2011 09:00 AM
Dumb electrical question about potentially overloading a power socket zapp Electrical 2 02-18-2011 10:43 AM
Wring for Lincoln Power Mig Welder vstoyko Electrical 17 01-15-2009 07:15 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
