Power Actuated Firing Pin Not Working - Tools - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 02:51 PM   #1
Handyman
Rewards Points: 512
Power actuated firing pin not working
Hey all...well, I loaned out my Remington 494 nailer to a friend and now it doesn't work. When I pull the trigger it just clicks but no shot. Anybody here ever fix theirs?
canadaclub is offline   Reply With Quote
Old 11-01-2010, 08:33 PM   #2
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I have never fixed one.
My suggestion was to have your 'Friend' Buy you a new one
Since they are no longer available you could do a disassamble and take a look see.
http://shoppingcart.msservicecompany...4/rem494bd.pdf
Disclaimer
& Stay Safe
.....Bob Lavery
Old 11-02-2010, 08:21 PM   #3
Registered User
Rewards Points: 526
Make sure it's not loaded. Look inside at the firing pin for part of a copper shell casing smashed/wedged over the recessed hole there. When that happens the pin will not be able to contact the end of the new load shot to fire, just a click. Hope that does it, they are pretty durable.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
oh'mike (11-03-2010)
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Power inverter AndrewL Electrical 6 03-02-2008 01:43 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
