Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 08-25-2007, 10:24 AM   #1
powder nailer
i bought a ramset cobra and went to use it in my basement to nail a shelf to the foundation wall. Basically i used a 2.5 inch nail through a 3/4 inch piece of wood. I used from the lowest to the highest power charge and all of them would not drive the nail fully into the wall. About 3/4 of an inch was left to be driven with the red powder charges. Am i doing something wrong or is that the concrete is just over 60 years old and is too hard for a nail of that size? Basically im left with some small concrete blowouts in the wall from pulling nails out, and the ones i shot with red charges i cant even pull out, the heads broke off after trying so hard to get them out.
JFD140 is offline   Reply With Quote
Old 08-25-2007, 02:25 PM   #2
powder nailer
Why not try shorter nails (1.5" or 2").
You already bought the expensive component(s).
Appears you are attempting to drive them a "bit" too deep for this wall.
JGarth is offline   Reply With Quote
Old 08-25-2007, 04:40 PM   #3
powder nailer
Why not just use a hammer drill and some tapcons?
We use those ramsat guns at work to install metal framing to steel joists or to concrete..Using it to hang a shelve seems a tad extreme..
Ryan03 is offline   Reply With Quote
Old 09-04-2007, 02:18 PM   #4
powder nailer
General rule is 1.5 to 2 times the thickness of the mat'l bieng fastened for the Penetration into concrete...... I'd be using a 2" or 2 1/4" long nail.........
mdlbldrmatt135 is offline   Reply With Quote
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 08:38 AM
What kind of Nailer? Oldhouseowner Tools 15 02-15-2009 07:36 PM
2hp / 6gal Compressor w/ framing nailer scarrell Tools 4 04-24-2006 09:34 AM
What size nailer to use for Soffit Replacement Mach5 Roofing 2 01-28-2006 12:24 PM
