Hi All, I'm a newbie here, and was searching this site because I was buying an air compressor for when I finish my basement. The kind I settled on was the porter cable CFNBNS pancake with 3 nailers because almost all who posted before were happy with it.
Anyway on to my question, might be dumb but here it is.
Is the proper way to drain the tank when finished the way it says in manual.
Manual says turn off, turn reg to zero, remove air tool, pull ring on saftey valve until pressure is at 20 psi release saftey ring and open drain?
Is that the way everyone does it because when I did it I almost crapped myself when air popped out?
when you pull ring it's at 150 psi, couldn't I just turn off and use sprayer to remove air in tank?
Thanks,
ctkulig
