Pocket Hole Tools - Tools - DIY Chatroom Home Improvement Forum
Old 06-06-2010, 08:05 PM   #1
Rewards Points: 31
pocket hole tools
has anyone used the Kreg pocket hole system, if so how is it, is it worth the investment, considering buying one, would like to hear pros/cons
jjchips is offline   Reply With Quote
Old 06-06-2010, 09:03 PM   #2
Concrete & Masonry
Rewards Points: 530
I have the very simple blue plastic set-up. It was probably only $40 or less, but money well spent IMO. Once you have it, you'll be pocket screwing everythign together.
If I used it professionally, I'm sure I'd spend more on a better set-up though.
jomama45 is offline   Reply With Quote
Old 06-07-2010, 08:06 AM   #3
I'd second that.
Bought the two hole jig about 18 months ago and love it. Fast and easy to use and definitely a very strong joint. My only regret has been on some larger projects that I didn't get one of the higher capacity models they offer.
jlc
jlc791 is offline   Reply With Quote
Old 06-07-2010, 06:56 PM   #4
firehawkmph's Avatar
Rewards Points: 1,826
I bought the original kreg set when they first came out. A couple years later they made some nice improvements and I bought the master set. Use them both. Wonderful tool, fun and easy to use. Once you start using it and realize how easy it is, you'll find many more uses for it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 06-07-2010, 10:20 PM   #5
Rewards Points: 266
Add this to my long list of gotta have tools.
Jim F is offline   Reply With Quote
Old 06-25-2010, 10:35 PM   #6
Remodeling Contractor
I'm a contratctor and use my Kreg jigs all the time when building cabinets. I love them, very strong joints. But I would recommend getting a bigger kit, not just the "starter" model if you are going to be doing some bigger projects with it. You get quite a bit more value out of the larger kits.
eisert is offline   Reply With Quote
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
Kreg K3 pocket hole kit Daveylad Carpentry 18 12-09-2008 10:01 PM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
