Plate Compactor - Tools - DIY Chatroom Home Improvement Forum
Old 05-24-2014, 08:51 AM   #1
Rewards Points: 240
plate compactor
i am going to need to compact my paver patio. the plate compactor i have only has the steel bottom. i am thinking its not a good idea to run this over the pavers.
any ideas on something economical to do ? i am thinking about strapping a piece of plywood to the bottom.
Fix'n it is offline   Reply With Quote
Old 05-24-2014, 12:55 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Those steel-plate compactors are used for that purpose all the time. That's how it is done. Go for it!
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Fix'n it (05-25-2014)
Old 05-25-2014, 10:04 AM   #3
landfillwizard's Avatar
Rewards Points: 516
Put a layer of sand over the pavers first then pound like crazy. The sand will fill in the cracks and also keep from breaking the pavers. I learned that the hard way!
landfillwizard is offline   Reply With Quote
Old 05-25-2014, 10:37 AM   #4
Rewards Points: 240
that makes sense. but i remember seeing a vid where they said NOT to use sand when compacting the pavers. idk why. seems like it would work well. though it may damage the ssurface of the pavers. convercely, the sand may spiff up the pavers.
Old 05-25-2014, 10:37 AM   #5
Rewards Points: 240
i think i will test that out today.
Old 05-27-2014, 07:49 PM   #6
Rewards Points: 410
Only one of many local rental outfits were willing to put a rubber pad on there compactor.
I had pavers with an irregular finish and it would scuff without it.
Rubber pad works slick!!
High Gear is offline   Reply With Quote
Old 05-27-2014, 08:19 PM   #7
Rewards Points: 240
i didn't test it out. as it turns out, i am barely going to have enough field pavers. so i don't want to damage any.
i will have some damaged leftovers to test the sealers/colors on.
i believe they are cast cement pavers. i know they are not an expensive type.
Old 06-05-2014, 08:57 PM   #8
Rewards Points: 240
i did some compacting today. i put down a sheet of osb. it worked pretty darned well ! my paver laying skills need more work = not quite flat. but the osb evened everything out nicely.
i tried it just a little on just the pavers. it left some scuffing, that i think/hope will brush out.
i stopped when i saw the scuffing.
Using a Plate Compactor for stone patio MurphyMan Concrete, Stone & Masonry 17 12-09-2014 08:32 AM
Should I buy a cheapo plate compactor? BrandonC_1972 Landscaping & Lawn Care 4 08-21-2012 10:31 PM
Brick pavers and plate compactor wvphysics Building & Construction 10 05-11-2011 09:49 AM
paver patio - is plate compactor necessary? jelconga Landscaping & Lawn Care 3 07-18-2010 05:52 AM
Paver install-hand tamper vs plate compactor bigboyjoel Landscaping & Lawn Care 9 07-23-2008 02:48 PM
