Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 02-09-2013, 10:53 AM   #1
Cruising into the sunset
JulieMor's Avatar
Planer Problems
I have a Delta 22-560 that was purchased right when that model came out. I use it a lot. A few years ago the wood began to stick. I solved that by helping it out manually. Lately the problem has been getting worse and it's like I'm doing all the work feeding the lumber through. It's more like a workout.
I've also noticed burnishing on the side being planed. It leaves grooves in the wood that have to be hand planed or sanded out. It's not the blade, I just changed them, these are pressed in. I'm thinking the feeder rollers are either damaged or have some kind of buildup on them.
Can these problems be fixed? Or am I in for a new planer purchase?
JulieMor is offline   Reply With Quote
Old 02-09-2013, 11:06 AM   #2
Planer Problems
Got to clean the rollers, may be a build up of sap.
Mineral spirts should work.
Old 02-09-2013, 12:25 PM   #3
JulieMor's Avatar
Planer Problems
Thanks Joe. I never "looked under the hood" before.
I was able to clean the rollers but the infeed roller rubber is damaged. There's a couple of tears in it and, where the burnished lines are showing up on the lumber, the rubber on the roller is grooved.
Now I'll have to see if I can replace it (and find the part) or if I'll have to have it serviced.
Old 02-09-2013, 03:56 PM   #4
JulieMor's Avatar
Planer Problems
I removed the infeed roller, without issue. It is in pretty bad shape and most likely the bulk of my problems. I found a replacement and should be back online in a few weeks. The roller has to be ordered from Delta.
Old 02-09-2013, 03:59 PM   #5
Planer Problems
Cool beans.
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Owen or Certain Teed has less problems?? reeses Roofing 10 02-07-2009 09:35 PM
Determining whether or not you have foundation problems? rmartin1286 Building & Construction 8 01-23-2009 09:09 AM
steam heat problems alanliz HVAC 8 01-18-2009 09:10 AM
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
