Planer Problems
1K views 4 replies 2 participants last post by  joecaption
I have a Delta 22-560 that was purchased right when that model came out. I use it a lot. A few years ago the wood began to stick. I solved that by helping it out manually. Lately the problem has been getting worse and it's like I'm doing all the work feeding the lumber through. It's more like a workout.
I've also noticed burnishing on the side being planed. It leaves grooves in the wood that have to be hand planed or sanded out. It's not the blade, I just changed them, these are pressed in. I'm thinking the feeder rollers are either damaged or have some kind of buildup on them.
Can these problems be fixed? Or am I in for a new planer purchase?
Thanks Joe. I never "looked under the hood" before. :icon_redface:
I was able to clean the rollers but the infeed roller rubber is damaged. There's a couple of tears in it and, where the burnished lines are showing up on the lumber, the rubber on the roller is grooved.
Now I'll have to see if I can replace it (and find the part) or if I'll have to have it serviced.
