Pipe Clamps - Tools - DIY Chatroom Home Improvement Forum
Old 06-21-2014, 09:08 PM   #1
Amazingfire's Avatar
Pipe Clamps
I'm looking at starting a pipe clamp arsenal and have been looking into them.
We got a Menards about 10 miles away that I shop at quite a bit with the little guy. I was wondering if anyone has and Pony brand pipe clamps and see if there any good. Menards has there tool shop ones for 4 dollars cheaper for both 1/2 and 3/4s.
Does anyone have size recommendations? I'm going to use them for building some cabinets and workshop table in the months coming
Roberts
Amazingfire is offline   Reply With Quote
Old 06-21-2014, 10:11 PM   #2
Civil Engineer
Rewards Points: 4,522
I have several Pony clamps, they work very well. By size I assume you mean pipe length. I have various pipes that range from two feet to 8 feet, I use the most appropriate size for the project I am working on. The Pony clamps use 3/4 inch pipe I believe. You may want to consider galvanized steel pipe, black iron pipe reacts with aliphatic (yellow) glue and can stain the wood, galvanized steel does not have that problem.
Old 06-22-2014, 03:12 AM   #3
(the original)
Rewards Points: 756
Pony clamps are good, come in both 3/4 and 1/2, but you can get very similar at HF for less. I have some of each and the Ponys are only a little better in fit and finish. Functionally, there isn't any significant difference. I really like the Besseys with the foot for things like face frames. Cabinet boxes and such are fine with the others.
ratherbefishin' is offline   Reply With Quote
Old 06-22-2014, 03:48 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
I did not know that about glue and black pipe. Luckily I have not had a problem so far.
I have two 3/4" black 8 footer HFT pipe clamps and two 4 footers very handy for building Bunk Beds for friends kids.
I bought three black pipe sections from HD and had them cut one of them in half then they cut new threads on the two raw ends.
........Note for Glue-Ups pipe clamps with a base as shown are easier to use.
also pipe clamps on 1/2" pipe bend like spaghetti.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-22-2014, 07:34 AM   #5
DIY staff
Rewards Points: 7,174
I have Pony and Harbor Freight clamps---you want pipe clamps with the metal plates to grab the pipe (like the picture Palibob posted)
Both brands work just fine----
Old 06-22-2014, 09:21 AM   #6
Rewards Points: 444
After the invention of Quick Grip by Vise Grip my pipe clamps have mostly stood in a corner. I tried using them to prop a door open once but even found them unhandy for that. I suspect they'll be on the next load of scrap iron that goes to the scrapper.
Old 06-22-2014, 09:27 AM   #7
DIY staff
Great~!---I'll drop by and pick up those old clamps---see you about 4:00
Old 06-22-2014, 10:08 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 840
^^^yes^^^^
Don't use the 1/2" clamps that you can get...not strong enough.
You don't have to have clamps for each size pipe. 2 4', 2 6', 2 8'....you can just move the clamp to the needed pipe....it then becomes easier to store the other pipes.
And I have a crap load of shorter clamps....you can never have enough clamps. And, yes, I have used ALL of them at one time.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Blondesense (06-23-2014)
Is this the right drainage pipe maddog1 General DIY Discussions 19 05-08-2014 09:46 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Wood-burning stove...connecting stovepipe to ceiling support box Laura J. Building & Construction 23 12-26-2011 01:49 AM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 02:05 AM
