Paslode Impulse Driver Blade Broke - Tools - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 12:30 PM   #1
Love for Construction
<*(((><'s Avatar
My Paslode 900420 impulse framing nailers' driver blade just broke (about 2" long piece) and fell out after shooting a nail. Anyone out there that has done work on these?
I would like to replace the driver blade as well as give this tool a thorough tune-up replacing any wear items that anyone is aware of. If someone happens to have a list of part numbers to buy for this project I would much appreciate it.
Also, if any of you have done what I'm about to do, is there anything I should know? And how difficult is it?
Thanks!
-luke-
<*(((>< is offline   Reply With Quote
Old 02-07-2012, 05:34 PM   #2
<*(((><'s Avatar
In fact I would settle for anyone to tell me which part on this diagram is the blade driver. I can't seem to find it. The blade that fell out was about 3/8" wide and about 1/8" thick and as far as length not sure as 2" of it broke off.
Paslode Parts Schematic - 900420
I have an email into Paslode parts, but have yet to hear back.
-luke-
Old 02-07-2012, 07:39 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,354
it usually takes a day or two to hear back from most tool manufacturers as they normally get large amounts of emails from all over the country
from what i can see its part 49,
woodworkbykirk is online now   Reply With Quote
Old 02-07-2012, 07:52 PM   #4
KemoSabe
loneframer's Avatar
Kirk is correct. 49 is the piston assembly, which includes the driver blade. Unless the cylinder is damaged, the piston and rings are typically all you should replace.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 02-08-2012, 07:53 AM   #5
<*(((><'s Avatar
That was my assumption that the driver blade was attached to the piston, but just wanted to make sure. thanks Kirk and Loneframer.
Loneframer, have you yourself dug that deep into one of these? I know you have a lot of impulse guns, just curious how difficult it is?
And is there any items you replace when tuning these up? The o-rings or the like?
-luke-
Old 02-08-2012, 02:18 PM   #6
lol, lone doesnt have a lot of them, he has a ton of em
How many Tooth Saw Blade for Trim? HandyFrank Carpentry 11 12-28-2011 07:11 PM
most efficient way to cut poured concrete floor Allthunbs Plumbing 10 12-16-2010 04:55 AM
Picked up my first impact driver ajtool Tools 8 10-31-2010 11:23 AM
Should I attempt to bring back my blade? Piedmont Carpentry 5 09-09-2010 04:26 PM
Porter Cable FR350 bad driver blade? timp Tools 6 05-20-2009 05:04 PM
