PASLODE IM350 Nailer Problem - Tools - DIY Chatroom Home Improvement Forum
Old 07-11-2007, 11:01 AM   #1
PASLODE IM350 nailer problem
Hi
I've just bought a paslode IM350 nailer off ebay, and the hammer doesn't go all the way back once it's fired (So the hammer doesn't engage with the head of the nail, it just sort of slides past it) IF I push the hammer back using a screwdriver etc. it fires one nail, and then it's back to square one.
Any ideas?
Cheers
Nick Liv
nickliv is offline   Reply With Quote
Old 07-11-2007, 11:43 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Discussion link:
http://www.contractortalk.com/showth...Paslode+Framer
Paslode link:
http://www.paslode.com/maintenance/usage.html
- Build Well -
Old 07-11-2007, 03:34 PM   #3
All sorted now. I took it to bits, and it was filthy. A goood clean with paraffin, and reassembly with fresh lube, and it's spot on now.
Old 07-13-2007, 06:25 AM   #4
Good. The key factor to Paslode framer operation is REGULAR CLEANING and maintenance.
Did you use the Paslode cleaner/degreaser and lubricant?
Did you follow the directions to do it properly?
- Build Well -
Old 04-01-2011, 09:03 AM   #5
Question
Paslode im350 problem
Hi,
I too am having some problems with my IM350 nail gun. I have just replaced all the O-rings and gave it a good clean, however, it will only fire once and it does not pick up a nail. The firing pin remains in the down position and will not fire again, until I have push it back with a screwdriver. Any help would be most welcomed.
paul830 is offline   Reply With Quote
Old 04-05-2011, 08:53 PM   #6
Rewards Points: 272
sounds like the hammer pin is bent. I have that gun and dropped it only to have that same problem. I repaired it and it works like a champ now.
Hope that helps
fixrite is offline   Reply With Quote
Old 04-05-2011, 09:07 PM   #7
KemoSabe
loneframer's Avatar
Yes, could be a bent driver, or possibly a piece of a broken nail head stuck in the guide. I've had that happen before.
After a good cleaning, it's important to oil the cylinder and piston rings for proper operation as well.
The piston should slide up and down the cylinder with very little effort.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 07-02-2011, 07:31 AM   #8
paslode im350
i have a paslode im350 nail gun and it wont fire.its all been cleaned but when you put it onto abit of wood there is no niose coming from it.when you pull away the fan started to run.can anyone help.would it be the sparking unit or something in the handle.
bargau5 is offline   Reply With Quote
Paslode pneumatic finish nailer Ken101 Tools 9 10-23-2011 09:55 AM
What kind of Nailer? Oldhouseowner Tools 15 02-15-2009 07:36 PM
Paslode angle finnish nailer problems phliphishin@sbcglobal.net Tools 3 04-16-2007 05:18 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 12:24 PM
