-   Tools (http://www.diychatroom.com/f29/)
-   -   PASLODE IM350 nailer problem (http://www.diychatroom.com/f29/paslode-im350-nailer-problem-9809/)
nickliv 07-11-2007 10:01 AM
Hi
I've just bought a paslode IM350 nailer off ebay, and the hammer doesn't go all the way back once it's fired (So the hammer doesn't engage with the head of the nail, it just sort of slides past it) IF I push the hammer back using a screwdriver etc. it fires one nail, and then it's back to square one.
Any ideas?
Cheers
Nick Liv
AtlanticWBConst. 07-11-2007 10:43 AM
Discussion link:
http://www.contractortalk.com/showth...Paslode+Framer
Paslode link:
http://www.paslode.com/maintenance/usage.html
nickliv 07-11-2007 02:34 PM
All sorted now. I took it to bits, and it was filthy. A goood clean with paraffin, and reassembly with fresh lube, and it's spot on now.
AtlanticWBConst. 07-13-2007 05:25 AM
Good. The key factor to Paslode framer operation is REGULAR CLEANING and maintenance.
Did you use the Paslode cleaner/degreaser and lubricant?
Did you follow the directions to do it properly?
paul830 04-01-2011 08:03 AM
Paslode im350 problem
Hi,
I too am having some problems with my IM350 nail gun. I have just replaced all the O-rings and gave it a good clean, however, it will only fire once and it does not pick up a nail. The firing pin remains in the down position and will not fire again, until I have push it back with a screwdriver. Any help would be most welcomed.:(
fixrite 04-05-2011 07:53 PM
sounds like the hammer pin is bent. I have that gun and dropped it only to have that same problem. I repaired it and it works like a champ now.
Hope that helps
loneframer 04-05-2011 08:07 PM
Yes, could be a bent driver, or possibly a piece of a broken nail head stuck in the guide. I've had that happen before.
After a good cleaning, it's important to oil the cylinder and piston rings for proper operation as well.
The piston should slide up and down the cylinder with very little effort.
bargau5 07-02-2011 06:31 AM
paslode im350
i have a paslode im350 nail gun and it wont fire.its all been cleaned but when you put it onto abit of wood there is no niose coming from it.when you pull away the fan started to run.can anyone help.would it be the sparking unit or something in the handle.
