Paslode Framer Wont Fire - Tools - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 06:26 PM   #1
Paslode framer wont fire
Hi I have a cordless paslode framing gun and it has stopped fireing.I have pulled it apart and cleaned and oiled it, its like the fireing pin wont pick up the nails or fire gas is good and battery good, any help would be great
Cheers
Greg
7cliffy1 is offline   Reply With Quote
Old 03-10-2012, 10:10 PM   #2
remodeling pro
What doyou mean that the gas is good? There are two very common gas problems.
You can have a cyliynder that sounds like it has lots of gas from the sound when you depress the tip, but it can not be enough pressure to fill the gun.
The second one is to check the expiration date stamped on the gas cylinder. "Old" gas looses it's power.
Have brought mine in to be repaired, only to be embarrasingly shown that these were the problems.
There can also be a problem with the safety contact in the tip.
troubleseeker is offline   Reply With Quote
Old 03-11-2012, 07:10 AM   #3
Ditto.........what he said. The gas has a fairly short life.
Old 03-11-2012, 05:53 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,208
were the fuel cells stored out in the cold.. if so this can shorten the cells life..
woodworkbykirk is online now   Reply With Quote
Light Fire Restoration / Odor Concerns gkotlin Painting 9 01-19-2012 06:40 AM
Electrical Fire seansy59 Electrical 1 10-24-2011 05:57 PM
Do they make internet enabled fire detectors? Red Squirrel Safety 3 08-30-2010 03:39 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 07:55 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
