Painting My Cabinets Need Some Advice - Tools - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 11:00 AM   #1
Painting my cabinets need some advice
Hello! I'm starting a project that depending on who you talk to is either a complete nightmare or easy peasy. I want to pain my old cabinets a new color. I believe I have educated myself pretty well for a person who has never done this before. My husband and I recently purchased a new home and as we all know after dropping that much money DIY is where it's at. I'm looking for any recommendations for paint sprayers. I'm looking for a quality tool without breaking the bank. One that doesn't jam up and works well. I was wondering if anyone would have some suggestions or ideas on how to start looking for one without a millions trips to Home Depot to return and try again. Thank you in advance!
Heather
uumpabo1 is offline   Reply With Quote
Old 09-01-2013, 06:16 PM   #2
Rewards Points: 77
I'd suggest renting a professional unit for the project. Will be cheaper than investing in a sprayer and give better results, especially if you don't plan on painting projects.
Justins1171 is offline   Reply With Quote
Old 09-01-2013, 06:22 PM   #3
K&B Designer
Live_Oak's Avatar
Unless you have glossy slab front cabinets, the best paint sprayer for a newbie is a high quality brush and some Floetrol additive to a good latex enamel paint. Plus about a month's worth of prep work on the cabinets, sanding, and priming.
If you have glossy slab front cabinets, the best spray rig will be an automotive body shop where someone who has experience sprays them. That's not for a newbie sprayer either.
Live_Oak is offline   Reply With Quote
Old 09-01-2013, 06:25 PM   #4
Rewards Points: 12,794
No way would I suggest a first time DIY try to spray paint cabinets!
Way to high a learning curve.
I've never even see a pro spray paint cabinets without completely removing them first.
With the right paint a tools you can get an except able job doing it by hand.
A quality sash brush and a foam roller is what I use.
Going to have to clean the cabinets first with TSP. Rinse them. Then sand to remove any flaws and to rough up the surface so it will hold the new primer and paint.
Going to need a bonding primer first.
Old 09-03-2013, 12:46 AM   #5
Rewards Points: 1,442
I just did this same job, and I used a sprayer from Harbor Freight (item#47016).
You will meed a small compressor as well. But if you're going to be doing some DIY tasks, I'd buy one of the small pancake compressors that comes with a couple of nail guns (Porter-Cable PCFP12656).
Spraying the cabinets is actually VERY simple. Just make sure you cover everything that you don't want paint on...
ktkelly is offline   Reply With Quote
Old 09-03-2013, 08:21 AM   #6
Rewards Points: 5,974
I must be doing it wrong.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (09-15-2013)
Old 09-03-2013, 10:17 AM   #7
Maybe so...
I've done it this way multiple times and it works well.
Used the same set up to paint some crown molding, door/window casing, and some fiberglass porch columns.
Old 09-03-2013, 10:42 AM   #8
I have used the wagner sprayers, an HVLP (High Vollume, Low Pressure) sprayers, and compressor/sprayer combinations. I also have one of the sparyers which pull paint from a can. I prefer the latter three over the wagner, but the best, in my experience, depends on paint viscosity and finish desired. For cabinets, I would probably opt for the compressor/spraygun option.
I agree with the comment about surface prep. This is 80% (or more?) of the work involved.
I have gotten to the point that I am satisfied with my results, sprayer or brush. The biggest lesson learned for me is to avoid putting too heavy a coat...using multiple thin coats rather than trying to accomplish this with a heavy single coat. (Same lesson whether spraying or brush/roller.) Having said this, for my last finish job I used a brush and was also satisfied with this. I don't like to spray indoors, and don't like the wasted paint associated with sprayers. I use sprayers only when outside, and only when the object has lots of small detail.
I also agree that a compressor is a valuable tool for a DIY person, used for much more than painting.
oberkc is offline   Reply With Quote
Old 09-12-2013, 10:24 AM   #9
You are using a latex paint? What tip size are you using on your spray gun? I am having issues getting my gun to spray thick latex....even after thinning it.
Maybe so...
tango0202 is offline   Reply With Quote
Old 09-12-2013, 12:11 PM   #10
Rewards Points: 34
Another vote for brush & rollers. I'm no highly experienced painter, but I've started some projects the wrong way and some the right way. I believe there is just less to learn to get a good result with a brush.
IMO good results start with: Thorough Pep Work (ie. no, you can't just hide problem spots with paint). Good quality paint that is right for the job. Good brushes/rollers. Only then do you need to learn a bit of technique, but you'll have set yourself up for success. Start in the least visible spot possible to get your technique down.
midwestcoast is offline   Reply With Quote
Old 09-12-2013, 02:03 PM   #11
Yes, I am using latex paint.
Did thin it somewhat. Very little though.
The paint tip is what came in the "el cheapo" HVLP from Harbor Freight (Item #47016).
Used it to spray white high gloss on a bookcase just the other day, and that also worked really well.
Advice for update of old cabinets on a budget cathjames Remodeling 14 09-17-2013 01:52 AM
Looking for feedback & advice on how to make kitchen cabinets look good! satori14u Kitchen & Bath Remodeling 2 11-09-2012 03:37 PM
Seeking advice on repaired drywall section painting shdowflare Painting 9 12-16-2011 04:55 PM
Painting & glazing kitchen cabinets btouchard Painting 2 05-17-2010 11:29 AM
Finishing Cabinets -- Wow. Need advice! Patriot_RAM Painting 15 08-09-2007 10:55 PM
