-   Tools (http://www.diychatroom.com/f29/)
-   -   Painting my cabinets need some advice (http://www.diychatroom.com/f29/painting-my-cabinets-need-some-advice-186297/)
uumpabo1 09-01-2013 10:00 AM
Hello! I'm starting a project that depending on who you talk to is either a complete nightmare or easy peasy. I want to pain my old cabinets a new color. I believe I have educated myself pretty well for a person who has never done this before. My husband and I recently purchased a new home and as we all know after dropping that much money DIY is where it's at. I'm looking for any recommendations for paint sprayers. I'm looking for a quality tool without breaking the bank. One that doesn't jam up and works well. I was wondering if anyone would have some suggestions or ideas on how to start looking for one without a millions trips to Home Depot to return and try again. Thank you in advance!
Heather
Justins1171 09-01-2013 05:16 PM
I'd suggest renting a professional unit for the project. Will be cheaper than investing in a sprayer and give better results, especially if you don't plan on painting projects.
Live_Oak 09-01-2013 05:22 PM
Unless you have glossy slab front cabinets, the best paint sprayer for a newbie is a high quality brush and some Floetrol additive to a good latex enamel paint. Plus about a month's worth of prep work on the cabinets, sanding, and priming.
If you have glossy slab front cabinets, the best spray rig will be an automotive body shop where someone who has experience sprays them. That's not for a newbie sprayer either.
joecaption 09-01-2013 05:25 PM
No way would I suggest a first time DIY try to spray paint cabinets!
Way to high a learning curve.
I've never even see a pro spray paint cabinets without completely removing them first.
With the right paint a tools you can get an except able job doing it by hand.
A quality sash brush and a foam roller is what I use.
Going to have to clean the cabinets first with TSP. Rinse them. Then sand to remove any flaws and to rough up the surface so it will hold the new primer and paint.
Going to need a bonding primer first.
ktkelly 09-02-2013 11:46 PM
I just did this same job, and I used a sprayer from Harbor Freight (item#47016).
You will meed a small compressor as well. But if you're going to be doing some DIY tasks, I'd buy one of the small pancake compressors that comes with a couple of nail guns (Porter-Cable PCFP12656).
Spraying the cabinets is actually VERY simple. Just make sure you cover everything that you don't want paint on...:)
ToolSeeker 09-03-2013 07:21 AM
I must be doing it wrong.
ktkelly 09-03-2013 09:17 AM
Maybe so...:wink:
I've done it this way multiple times and it works well.
Used the same set up to paint some crown molding, door/window casing, and some fiberglass porch columns.
oberkc 09-03-2013 09:42 AM
I have used the wagner sprayers, an HVLP (High Vollume, Low Pressure) sprayers, and compressor/sprayer combinations. I also have one of the sparyers which pull paint from a can. I prefer the latter three over the wagner, but the best, in my experience, depends on paint viscosity and finish desired. For cabinets, I would probably opt for the compressor/spraygun option.
I agree with the comment about surface prep. This is 80% (or more?) of the work involved.
I have gotten to the point that I am satisfied with my results, sprayer or brush. The biggest lesson learned for me is to avoid putting too heavy a coat...using multiple thin coats rather than trying to accomplish this with a heavy single coat. (Same lesson whether spraying or brush/roller.) Having said this, for my last finish job I used a brush and was also satisfied with this. I don't like to spray indoors, and don't like the wasted paint associated with sprayers. I use sprayers only when outside, and only when the object has lots of small detail.
I also agree that a compressor is a valuable tool for a DIY person, used for much more than painting.
tango0202 09-12-2013 09:24 AM
You are using a latex paint? What tip size are you using on your spray gun? I am having issues getting my gun to spray thick latex....even after thinning it.
Originally Posted by ktkelly (Post 1237530)
Maybe so...:wink:
midwestcoast 09-12-2013 11:11 AM
Another vote for brush & rollers. I'm no highly experienced painter, but I've started some projects the wrong way and some the right way. I believe there is just less to learn to get a good result with a brush.
IMO good results start with: Thorough Pep Work (ie. no, you can't just hide problem spots with paint). Good quality paint that is right for the job. Good brushes/rollers. Only then do you need to learn a bit of technique, but you'll have set yourself up for success. Start in the least visible spot possible to get your technique down.
ktkelly 09-12-2013 01:03 PM
Yes, I am using latex paint.
Did thin it somewhat. Very little though.
The paint tip is what came in the "el cheapo" HVLP from Harbor Freight (Item #47016).
Used it to spray white high gloss on a bookcase just the other day, and that also worked really well.
