Overkill Use Of Power Tools! - Tools - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 11:19 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
overkill use of power tools!
What is the most overkill thing you have used a power tool for?
Just now I had to cut up some big cardboard boxes to put out on the curb, and my circular saw was the closest cutting tool. Wow, it went well.
Old 12-31-2010, 05:16 AM   #2
Oldguy
Rehabber's Avatar
There is no tool too big or too powerful.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-31-2010, 02:38 PM   #3
Rewards Points: 502
circular saws make very good cuts in cardboard. I don't know of a better tool for the job.
I've used a heavy duty sawzall to cut cut open a plastic retail package a couple of times
I've used a Dresser TD8 dozer to move a trailer.
I've picked up the empty garbage cans with the front end loader on a Compact utility tractor
I've moved a 20 lb box with a 5k lbs hi-lo
and to top it all off.....
I've picked up a check with a Semi tractor and 53' van Trailer!
forresth is offline   Reply With Quote
Old 12-31-2010, 02:42 PM   #4
Overkill would be using a sawzall to field-dress a deer.
clashley is offline   Reply With Quote
Old 12-31-2010, 08:15 PM   #5
Household Handyman
Rewards Points: 1,408
Geeez, "forresth" That must have been some nice sized check.
Old 01-02-2011, 02:17 AM   #6
I used my Milwaukee corded hole hog with a 1/4" bit to drive zip screws in 26 GA galvanized.
hvaclover is offline   Reply With Quote
Old 01-02-2011, 02:21 AM   #7
Actually that is not a bad ideas. We have electric craving knife for turkeys don't we?
Never did a deer to honest though
Old 01-02-2011, 09:11 AM   #8
Rewards Points: 502
I've heard of chainsaws with vegi oil in place of bar and chain oil to quarter large game that needs to be packed out, so a Sawzall for deer isn't entirely without precedent
Old 01-02-2011, 09:56 AM   #9
Carpenter
dtsman's Avatar
I've used my power miter saw to cut popsicle sticks for one of my kids projects.
Bo
Remember, If the women don't find you handsome,
they should at least find you handy.
(Red Green)
dtsman is offline   Reply With Quote
Old 01-02-2011, 04:39 PM   #10
Wire Chewer
Rewards Points: 132
Unless said sawzall is plugged into a 600KW diesel generator sitting on a tri-axle trailer.
Old 01-03-2011, 02:47 AM   #11
Sheeesh...I think you'd need to invent a new blade for for game butchering.
Just a little side track here..I think it's funny:
Talking about other uses of a sawzall...I lost my corded sawall to my wife.
She prunes the trees and bushes on our property...I don't really need it cause my cordless Milwaukee does everything I need it too.
But if i did try to take it back I think my wife would use it on me lol.
Old 01-03-2011, 10:32 AM   #12
Rewards Points: 502
actually I picked up a Ryobi pruner, it was obviously a cordless sawzall on a pole with a prune blade. I was real cheap, and I wanted a cordless sawzall, so I got it.
Ps. how about a 10kw generator screaming away to run the Mr. Coffee?
Old 01-03-2011, 11:44 AM   #13
Naw...my customers have been with me going on 30years--they have the coffee waiting when I get there. And they remember how i take it too.
The perks of being a one man shop.
Old 01-10-2011, 11:14 PM   #14
It works better than you'd think. I have some stainless steel blades for my 28 volt cordless Milwaukee and its great for sawing through a pelvis. I've used it to cut off the feet too but I found that pruning shears work better for that.
Frank Martin is offline   Reply With Quote
Old 01-10-2011, 11:54 PM   #15
Mine is only 18v.
How do I get power to a new ceiling fan? sestivers Electrical 15 10-10-2016 04:16 PM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 09:38 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
