Out of the box Generac won't start
Any help would be appreciated. XG8000e, oil added, didn't fill fuel tank,but should be enough, w/electric start.
did you read the manual that came with it? if it is new out of the box and won't run i would return it for one that does.
Did you open the valve from the tank to the carberator?
Remove the air filter, open up the choke and give it a shot of starting fluid. |
Thanks for the responses, I figured out the plug wasn't getting any fuel. Joe thats exactly what I did, removed air filter and shot some starter fluid in there and started right, ran fine after that. thanks again guys.......
| All times are GMT -4. The time now is 12:05 PM. |
