Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Poll: Which Oscillating Tool do you prefer?
Poll Options
Old 04-19-2010, 04:12 PM   #1
gmhammes's Avatar
Oscillating tool poll
Okay, i know there has been multiple threads on these tools.
I am still debating however and would greatly appreciate you selecting which brand os Oscillating tool you prefer.
I am leaning towards one of them but i won't say which yet.
Let the poll begin...
FYI... that is not supposed to be a frown in the other option! lol i was trying for
Other: (Specify in a comment please)
gmhammes is offline   Reply With Quote
Old 04-19-2010, 04:17 PM   #2
Tool Geek
PaliBob's Avatar
Thumbs up
Fein Multimaster
& Stay Safe
.....Bob Lavery
Old 04-19-2010, 04:29 PM   #3
gmhammes's Avatar
Originally Posted by PaliBob View Post
Fein Multimaster
I noticed that you have mentioned the commercial grade model before. Obviously that is not in my price range. How is the FMM 250Q?
Old 04-19-2010, 05:02 PM   #4
Tool Geek
PaliBob's Avatar
Originally Posted by gmhammes View Post
I noticed that you have mentioned the commercial grade model..............
Fein tools are all expensive but the MultiMaster is NOT their commercial model.The Fein commercial line is called the 'SuperCut'
http://www.feintools.us/index.php?c=..._Carpenter_kit
........How is the FMM 250Q?
The Fein consumer grade FMM 250Q MultiMaster usually goes for ~$400
I have an older MM in the metal case and consider it one of most valued tools.
http://www.amazon.com/gp/offer-listi...ag=dear0356-20
& Stay Safe
.....Bob Lavery
Old 04-22-2010, 03:20 AM   #5
Tool Geek
PaliBob's Avatar
Fein offers a stripped down Multimaster Starter Kit for ~ $200
Same motor as the more expensive kits with all the accessories.
I get more blades (high quality) at a more reasonable price from:
http://multiblades.com/
& Stay Safe
.....Bob Lavery
Old 04-27-2010, 10:44 AM   #6
Dude, I just wanted to check out how they worked before spending big bucks. Bought a cheap one at Harbor Freight. $39.00 with sanding,cutting, and scraping attachments I love it
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
loneframer (06-09-2011)
Old 04-27-2010, 05:05 PM   #7
Tool Geek
PaliBob's Avatar
I would not be afraid to buy from HF
I do not know though, if the blades are interchangeable with any of the other brands.
Does anybody here know?
http://www.harborfreight.com/cpi/cta...116&pricetype=
& Stay Safe
.....Bob Lavery
Old 04-28-2010, 08:33 AM   #8
I bought the HF tool but buy Dremel attachements. Yes, they are interchangeable. Same size shaft.
The multitool (whatever the brand) is a game changer. I was putting a door switch in a door jam. Usual technique is to drill most of it out and then beat the rest out with a wood chisel. The multitool let me plunge cut straight lines, splitting the pencil layout and removing exactly the size block of wood I wanted removed. A real carpenter could do the same thing with chisels. But I'm just a pretend carpenter. I was laying a subfloor and it got snagged on a door molding. It was awkward and I didn't want to have to discombobulate everything so I could try to saw off the bottom of the molding. So instead, I grabbed the multitool, which is the only tool that will let you cut flush to a surface. It shaved the molding so close to the subfloor that there is no visible gap.
I'm a believer.
I tend to go to HF because they are substantially cheaper and I don't have to make a living with the stuff. If I end up not using it much, I'm not out a lot of money. If I use something extensively and it breaks, then I replace it with a better brand. If it doesn't break, I don't replace it.
mwpiper is offline   Reply With Quote
Old 04-28-2010, 09:39 AM   #9
gmhammes's Avatar
Got my Fein in Yesterday... I am a believer, just need to find more things to do around the house with it! lol
Old 04-28-2010, 12:22 PM   #10
Tool Geek
PaliBob's Avatar
I congratulate your enthusiasm, however when you said:
Originally Posted by mwpiper View Post
.......I grabbed the multitool, which is the only tool that will let you cut flush to a surface.
This is not True. It is an offset tool blade not the tool brand that will make a cut flush to a surface.
Here is a tool blade supplier that has blades for all the Oscillating Tools that I know. If you go through the ‘Tool Selection’ list on this site, you will see that offset blades are available for all brands of oscillating tools.
http://www.imperialblades.com/Produc...ductCode=MM250
& Stay Safe
.....Bob Lavery
Old 04-28-2010, 01:28 PM   #11
gmhammes's Avatar
I'm going to have to start bookmarking these blade sites as i know i will hit a project that requires a different blade soon!
Old 04-30-2010, 09:45 AM   #12
Tool Cop
I congratulate your enthusiasm, however when you said: This is not True. It is an offset tool blade not the tool brand that will make a cut flush to a surface.
Here is a tool blade supplier that has blades for all the Oscillating Tools that I know. If you go through the ‘Tool Selection’ list on this site, you will see that offset blades are available for all brands of oscillating tool.
Wow... those blades are so much cheaper than buying them from Rockwell...
TrafficCopSmith is offline   Reply With Quote
Old 04-30-2010, 10:34 AM   #13
are they same quality of steel?
The older I get the better I was
Old 04-30-2010, 04:19 PM   #14
Tool Geek
PaliBob's Avatar
I don't know about the blades from "Imperial Blades" but the Sonicrafter blades from Multiblades have hardened teeth and are extra long, with cutting depths of 1-3/4" or 2" and go for $11
& Stay Safe
.....Bob Lavery
The Following User Says Thank You to PaliBob For This Useful Post:
BlueStoneFloors (08-20-2011)
Old 06-09-2011, 11:42 AM   #15
uva uvam videndo variafit
WirelessG's Avatar
I see that Amazon has reconditioned Dremel MT's on sale for $44 (one day sale). I don't generally care for reconditioned tools and I generally try to buy top of the line (fein), but at this price, why not?
http://www.amazon.com/gp/goldbox/ref...290_pe_00_head
WirelessG is offline   Reply With Quote
Fein's Multimaster Tool...don't let the price scare you! CrossWorks Tools 13 04-18-2009 07:39 PM
Drywall Inside Corner Tool? helpless handyman Drywall & Plaster 24 02-19-2009 07:02 PM
Tool conglomerations, who owns who ? iMisspell Tools 19 01-27-2009 01:41 PM
the tool for mounting real short nipples amakarevic Plumbing 2 11-01-2008 01:34 AM
Tub Drain Removal Tool rjordan392 Plumbing 6 07-08-2008 12:39 PM
