-   Tools (http://www.diychatroom.com/f29/)
-   -   Oscillating tool poll (http://www.diychatroom.com/f29/oscillating-tool-poll-69387/)
gmhammes 04-19-2010 03:12 PM
Okay, i know there has been multiple threads on these tools.
I am still debating however and would greatly appreciate you selecting which brand os Oscillating tool you prefer.
I am leaning towards one of them but i won't say which yet.
Let the poll begin...
FYI... that is not supposed to be a frown in the other option! lol i was trying for
Other: (Specify in a comment please)
PaliBob 04-19-2010 03:17 PM
Fein Multimaster :thumbsup:
gmhammes 04-19-2010 03:29 PM
I noticed that you have mentioned the commercial grade model before. Obviously that is not in my price range. How is the FMM 250Q?
PaliBob 04-19-2010 04:02 PM
Originally Posted by gmhammes (Post 430704)
I noticed that you have mentioned the commercial grade model..............
Fein tools are all expensive but the MultiMaster is NOT their commercial model.The Fein commercial line is called the 'SuperCut'
http://www.feintools.us/index.php?c=..._Carpenter_kit
........How is the FMM 250Q?
The Fein consumer grade FMM 250Q MultiMaster usually goes for ~$400
I have an older MM in the metal case and consider it one of most valued tools.
http://www.amazon.com/gp/offer-listi...ag=dear0356-20
PaliBob 04-22-2010 02:20 AM
Fein offers a stripped down Multimaster Starter Kit for ~ $200
Same motor as the more expensive kits with all the accessories.
I get more blades (high quality) at a more reasonable price from:
http://multiblades.com/
plumberinlaw 04-27-2010 09:44 AM
Dude, I just wanted to check out how they worked before spending big bucks. Bought a cheap one at Harbor Freight. $39.00 with sanding,cutting, and scraping attachments I love it
PaliBob 04-27-2010 04:05 PM
I would not be afraid to buy from HF
I do not know though, if the blades are interchangeable with any of the other brands.
Does anybody here know?
http://www.harborfreight.com/cpi/cta...116&pricetype=
mwpiper 04-28-2010 07:33 AM
I bought the HF tool but buy Dremel attachements. Yes, they are interchangeable. Same size shaft.
The multitool (whatever the brand) is a game changer. I was putting a door switch in a door jam. Usual technique is to drill most of it out and then beat the rest out with a wood chisel. The multitool let me plunge cut straight lines, splitting the pencil layout and removing exactly the size block of wood I wanted removed. A real carpenter could do the same thing with chisels. But I'm just a pretend carpenter. I was laying a subfloor and it got snagged on a door molding. It was awkward and I didn't want to have to discombobulate everything so I could try to saw off the bottom of the molding. So instead, I grabbed the multitool, which is the only tool that will let you cut flush to a surface. It shaved the molding so close to the subfloor that there is no visible gap.
I'm a believer.
I tend to go to HF because they are substantially cheaper and I don't have to make a living with the stuff. If I end up not using it much, I'm not out a lot of money. If I use something extensively and it breaks, then I replace it with a better brand. If it doesn't break, I don't replace it.
gmhammes 04-28-2010 08:39 AM
Got my Fein in Yesterday... I am a believer, just need to find more things to do around the house with it! lol
PaliBob 04-28-2010 11:22 AM
I congratulate your enthusiasm, however when you said:
Originally Posted by mwpiper (Post 434660)
.......I grabbed the multitool, which is the only tool that will let you cut flush to a surface.
This is not True. It is an offset tool blade not the tool brand that will make a cut flush to a surface.
Here is a tool blade supplier that has blades for all the Oscillating Tools that I know. If you go through the ‘Tool Selection’ list on this site, you will see that offset blades are available for all brands of oscillating tools.
http://www.imperialblades.com/Produc...ductCode=MM250
gmhammes 04-28-2010 12:28 PM
I'm going to have to start bookmarking these blade sites as i know i will hit a project that requires a different blade soon!
TrafficCopSmith 04-30-2010 08:45 AM
Originally Posted by PaliBob (Post 434764)
I congratulate your enthusiasm, however when you said: This is not True. It is an offset tool blade not the tool brand that will make a cut flush to a surface.
Here is a tool blade supplier that has blades for all the Oscillating Tools that I know. If you go through the ‘Tool Selection’ list on this site, you will see that offset blades are available for all brands of oscillating tool.
Wow... those blades are so much cheaper than buying them from Rockwell...
tpolk 04-30-2010 09:34 AM
are they same quality of steel?
PaliBob 04-30-2010 03:19 PM
I don't know about the blades from "Imperial Blades" but the Sonicrafter blades from Multiblades have hardened teeth and are extra long, with cutting depths of 1-3/4" or 2" and go for $11
WirelessG 06-09-2011 10:42 AM
I see that Amazon has reconditioned Dremel MT's on sale for $44 (one day sale). I don't generally care for reconditioned tools and I generally try to buy top of the line (fein), but at this price, why not?
http://www.amazon.com/gp/goldbox/ref...290_pe_00_head
