Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 09-29-2010, 11:57 AM   #1
Operator Presence Control bar cable - Craftsman mower
I was given a Craftsman 5.5 21" ,model 917.390xxx push mower that I can't start. Oil & gas clean, spark plug good. Then I noticed the operator presence control bar cable appears to be broken at about the halfway point (near the mower handle) . I don't have any experience with the presence bar mowers (my 30 y/o Toro still going strong, but I want to give it to my brother).
Does the Control Bar cable interrupt gas flow, or electrical,or something else, to prevent the mower from starting? Are these cables available for replacement? Can they be bypassed? (just to check if the mower will even start).
SixStrRzr is offline   Reply With Quote
Old 09-29-2010, 12:20 PM   #2
(the original)
The cable controls a safety switch that cuts off the spark when released. Don't try to bypass it or you'll have no way to shut off the mower other than pulling the spark plug cable. You can usually find the cable at any local repair shop cheaper than ordering from Sears.
ratherbefishin' is offline   Reply With Quote
Old 09-29-2010, 01:06 PM   #3
After digging around a little further, looks like APY made this mower, and the cables are pretty standard (dual Z-ends, bolt or snap-in) - I just have to measure & get the right length & ends. I'm guessing I can disconnect the existing one & tie-wire the engine switch to see if the motor even starts.
Old 09-29-2010, 03:30 PM   #4
DIY Hack
Mr Chips's Avatar
They are readily available and just have ends that clip in place. before you spend any $$ not knowing if anything else is wrong, you could try pulling the lower half tight, while someone tries to start it for you. At least then you'll know if it's worth spending money on
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 09:21 PM
Ariens or Craftsman Riding Mower? Osiris Landscaping & Lawn Care 3 04-20-2010 09:46 PM
Craftsman pull start bagging mower Yoyizit Landscaping & Lawn Care 4 05-09-2009 12:23 PM
craftsman mower problems ccrodeo425 Landscaping & Lawn Care 10 05-06-2009 06:45 PM
Craftsman Mower leaking gas? cwest94 Landscaping & Lawn Care 2 08-01-2008 10:51 PM
