Go Back   DIY Chatroom - DIY Home Improvement Forum > Equipment & Safety > Tools
Old 06-05-2012, 05:20 PM   #1
oil and gas mixture " used weed wacker"
I picked up an older weed wacker at a pawn shop has no instructions .. was curious what a good mix ratio should be , i always just sort of guessed but would like to get a better idea what it should be or what a safe ratio would be.
oldrivers is offline   Reply With Quote
Old 06-05-2012, 05:22 PM   #2
I have three and and several chain saws and they all take 50:1.
http://www.ehow.com/way_5990608_do-g...-trimmer_.html
Old 06-05-2012, 05:28 PM   #3
ok, i was about 30-1 and was smoking a little there. thanks .
Old 06-05-2012, 06:40 PM   #4
In a little over my head
If you use 50/1, make sure you're using an oil that will support that ratio. A lot of popular power eqipment oils are formulated for 32/1. Most of the 4oz bottles sold at the box stores add to a gallon of gas.
Who manufactured the weed wacker?
ratherbefishing is offline   Reply With Quote
Old 06-05-2012, 10:33 PM   #5
its a homelite name but not sure if thats the manufacturer.
Old 06-05-2012, 10:38 PM   #6
Are you 100% sure it's a 2 stoke. I own a Homelite that's a 4 stroke.
Simple to check, look for an oil dip stick.
Old 06-06-2012, 09:29 AM   #7
Newly Retired
tuchodi's Avatar
The mixing ratio is more about the oil than the motor you are using it in. Get a good quality oil that can mix at 50/1 and use that. I have switched over to Synthetic oil and I have noticed an incredible difference in how much easier they start and runs smother both at full load and at an idle.
tuchodi is offline   Reply With Quote
